valve spring removal
Postby kingcorolla » Fri Sep 17, 2004 5:25 pm
anyone know a good way to remove valve springs, at home?
(dont say use a valve spring compressor..)
1983 Carina AA63 4age
kingcorolla
Postby GOLDAE86 » Fri Sep 17, 2004 8:01 pm
It is a bit rough but have seen it done before. Grab a 13/16 spark plug socket and a hammer, place the plug socket over the valve collet, hit the socket with the hammer and the valve retainers should pop out,If they dont pop out then get the hammer and tap on the collet just so it helps to break the taper and repeat the process. Make sure you dont have the face of the head flat on a bench.
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby kingcorolla » Fri Sep 17, 2004 8:58 pm
ye i herd there was a way with the sparkplug socket, so i tryed just pushing on it, but couldnt get at the collets from there.
il try ure way latr tho, cheers
kingcorolla
Postby thaphatty » Fri Sep 17, 2004 9:02 pm
2 g-cramps can work, although time consuming and difficult, and you need the right sized ones, just clamp either side of valve and remove collets
thaphatty
Postby kingcorolla » Fri Sep 17, 2004 9:16 pm
thaphatty wrote:2 g-cramps can work, although time consuming and difficult, and you need the right sized ones, just clamp either side of valve and remove collets
u mmeen g-CLAMPS?, ye i got sum of them lyin around, ill have a muck around with it tomorrow.
kingcorolla
Postby kingcorolla » Sat Sep 18, 2004 1:59 am
i ended up filling a small bag up with sand, and put it in the combustion chamber, face down. To stop the valve depressing, just the spring. Twas easy from there 8)
kingcorolla
Postby Logan » Sat Sep 18, 2004 11:57 am
I woudlnt reccommend doing it with a bag of sand!! to much risk of putting a non axial loading on the valve. The hammer has trick worked everytime for me....
I assume the head is off??
Prop the head up with a couple of bits of wood so the valves dont/wont hit anything if they start to open. Get a socket/sparkplug socket etc and a decent size hammer and use swift heavy blows on an extension of similar. Has worked eveytime for me with a bit of perserverence.
May want to put a rag over/around the area so bits dont fly everywhere when they let go. Make sure you dont mix up what came from where, and which way up the springs came out...
Just wait till you have the fun of trying to reassemble them... :D
Logan
SR Sold. Onto Other Things
Logan
Postby Lloyd » Sat Sep 18, 2004 3:54 pm
Yeah, hammer and a socket that fits over is the easiest way. Getting them back in is the challenge
Postby thaphatty » Sat Sep 18, 2004 3:59 pm
haha! "g-cramps" sounds hilarious, and yes, i clamps :oops:
thaphatty
Postby kingcorolla » Sat Sep 18, 2004 6:06 pm
cheers for the help, ill let u know, it was an old fukkd 4k head, and ive got 4 of them.
i just put it on the bench, face down, and was rough, it wasnt a head i cared about :P
just wanted to know a easy way to do it quickly :wink:
kingcorolla
