warning fuel sign after putting in pertol. WAT DO I DO??
Postby JC » Mon Sep 20, 2004 5:46 pm
hi,
put in $20 into my AE86 tank and the low fuel sign is still on. WAT DO I DO??
J-Spec Group
"Keeping it true to the JDM"
http://jspecgroup.com/forum/index.php
JC
Postby CozmoNz » Mon Sep 20, 2004 5:55 pm
well, is the guage up?
if the guage is up, and the sensor still reads as empty, that means the sensor is fuxed. either that or REALLY high in the tanc... i think its when no fuel is around it it turns on, so it sits low in the tanc, thus when tanc low = light go on.
so it might be bung, or floatie :D.
either way, have fun :P
Rayne For President!
CozmoNz
Postby BlakJak » Mon Sep 20, 2004 6:07 pm
Dare I suggest it - FILL IT UP?
Does the light go out?
If my gas guages were doing funny things id wanna be filling it up and using the tripmeter to give myself a mental idea of when im likely to be short on gas...
BlakJak
Postby CozmoNz » Mon Sep 20, 2004 7:26 pm
BlakJak wrote:Dare I suggest it - FILL IT UP?
if he cant fill a car up when the guage goes down he dosnt deserve an ae86.....
CozmoNz
Postby kingcorolla » Mon Sep 20, 2004 8:25 pm
[not helping] my mate had a old bluebird, that when it had fuel in the tank, the light was on, but when it was low, the light turned off...worked opposite. No need to fix it! [/not helping]
1983 Carina AA63 4age
kingcorolla
Postby Chickenman » Mon Sep 20, 2004 8:37 pm
Some people need to learn how to play nice
Baby Jesus
Chickenman
I Am The Walrus!
Postby JC » Mon Sep 20, 2004 8:48 pm
did fill up the tank and still the low fuel sign is on and the fuel gauge is empty. mine is a electronic gauge so the fuel guage has no bar or any sign of full tank.
To CozmoNz,
WAT THE $&#$% is your problem?? if i am not having trouble i would not ask for help. but i do with this thing so if you are not helping.Mine your own $&#$% business and find some place except in tech questions where you belong.
J-Spec Group
JC
Postby Ae92typeX » Tue Sep 21, 2004 12:11 am
Im guessing (obviously) if you have now filled up and it still does not work that it is one of several things:
1: the plug for the sensor has somehow come off. Im not sure, but think they are on the inside of your car, either the boot or back seat- have you moved anything around that area lately.
2: the actual sender is stuck, or faulty. Either way that would mean taking it out- best to get the multimeter out to test that also.
3: the gauge cluster is not plugged in properly- however Im not sure this would make the light go on, maybe mabye-not.
4: something else I cannot think of at this time of night
Ae92typeX
Postby JC » Tue Sep 21, 2004 8:18 pm
Thanks alot. i will check those things that u mention out. Thank you so much
J-Spec Group
JC
faulty gauge?
Postby xtreme.drifting » Mon Feb 13, 2006 7:29 pm
anyone know how much it would cost to get a fuel gauge tested? approx cost.. e.g $20 or are we talking hundreds here?
xtreme.drifting
Postby Ae92typeX » Mon Feb 13, 2006 8:03 pm
can test if it moves with 9v/12v battery on the correct terminals. what type of car?
Ae92typeX
Postby matt dunn » Mon Feb 13, 2006 9:21 pm
JC wrote: mine is a electronic gauge so the fuel guage has no bar or any sign of full tank.
You mean digital dash?
We had an AE86 in with digi dash and man are they troublesome,
after three repairs in a year at about 300 each time I converted it to an Analogue dash type like a normal AE86.
This means you have to change the dash, fuel sender and oil sender, and speedo drive.
We got them as a set from a wrecker, but nowdays a complete set will be hard to find.
Matt
Postby Malcolm » Mon Feb 13, 2006 9:45 pm
FWIW this thread is a year and a half old. Ressurrected by a noob :P
Postby matt dunn » Mon Feb 13, 2006 9:49 pm
All_Fours wrote:FWIW this thread is a year and a half old. Ressurrected by a noob :P
Whoops,
Postby Ae92typeX » Mon Feb 13, 2006 10:06 pm
perhaps they were conserving topic threads lol :lol:
at least they must have done a search to find it!
Ae92typeX
Users browsing this forum: Google [Bot] and 25 guests
