Bleeding the cooling system to prevent head gasket blowing ?
Postby z|gen » Wed Sep 22, 2004 10:28 pm
hey..
umm..yeah, just put my new engine and radiator etc in..
and i think it will need a bleed to get all the air out, how do you go about this, cause i havent done one before..
cheers David
AE91 SUPERCHARGED COROLLA
z|gen
Postby Ae92typeX » Wed Sep 22, 2004 10:42 pm
If you jack the front up to make sure the radiator to is the highest point (usually is anyway), put the heater control onto hot (opens up the valve to it) and pour the water in it should do it. I did that with my supra and didnt get any water pockets.
Ae92typeX
Postby matt dunn » Wed Sep 22, 2004 11:48 pm
Ae92typeX wrote:If you jack the front up to make sure the radiator to is the highest point (usually is anyway), put the heater control onto hot (opens up the valve to it) and pour the water in it should do it. I did that with my supra and didnt get any water pockets.
Yes do that and then while it is still up at the front run the car with the radiator cap off and keep topping it up as the water level fluctuates untill the fan comes on ( presuming the radiator fan works) then put the cap on.
Fill the overflow bottle and it's all set.
(unless it's a mr2 as they have a quite complicated procedure)
Postby kingcorolla » Thu Sep 23, 2004 12:51 am
matt dunn wrote:(unless it's a mr2 as they have a quite complicated procedure)
ye tryin to do a coolant change on the 2zz in celica is a rite prick to.
1983 Carina AA63 4age
kingcorolla
Postby blitza » Thu Sep 23, 2004 12:03 pm
...and if its a new engine yoou should use water untill the head gasket has 'set', as coolabt has smaller molecules.
MAD Industries Limited
'97 GTT auto, -under rebuild, again.
the faster you go, the quicker you get there...
blitza
Postby z|gen » Thu Sep 23, 2004 2:50 pm
sweet, cheers guys
do i need to put coolant in at the same time, or just water and then coolant later ?
z|gen
Postby kingcorolla » Thu Sep 23, 2004 2:56 pm
lets not turn it into a big discussion on how to top it up.
just put the shitt in. IT DOESNT MATTER what u put in 1st, or how u put it in, as long as the coolant fill the cooling system, THATS IT!
kingcorolla
Postby z|gen » Thu Sep 23, 2004 3:17 pm
yo..calm down..sorry for trying to learn..
next time, il just try my luck and see what happens
thanks for everyones help
and if you read what people said, water - nowhere did it say also put coolant in, so thanks for your advice, greatly appreciated :)
- David
z|gen
Postby pc » Thu Sep 23, 2004 3:52 pm
Shouldn't you be using the terms water & antifreeze?
Coolent would be whatever you end up with in the radiator system, be it water, antifreeze or a combination of both.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Lloyd » Thu Sep 23, 2004 6:39 pm
And on that note, a 50/50 mix of antifreeze and water is what should be going in
Postby ChaosAD » Thu Sep 23, 2004 9:14 pm
My toyota mechanic was telling me about something about warming up the engine with no coolant at all in it until it felt warm when replacing a composite headgasket to help it set.
Anyone know nething about this?
ChaosAD
Postby Ae92typeX » Thu Sep 23, 2004 10:15 pm
ChaosAD wrote:My toyota mechanic was telling me about something about warming up the engine with no coolant at all in it until it felt warm when replacing a composite headgasket to help it set.
Ive never done that with head gaskets ive replaced over the years. It sounds a lil risky.
Ae92typeX
Coolant
Postby GOLDAE86 » Thu Sep 23, 2004 10:26 pm
The called baking the head gasket to the block and head surfaces.It ensures a good seal.I have done it many times and never had any problems.Just run the engine for 1-2minutes then turn the engine off, wait until the engine has cooled then add only water to system.Add the anti freeze at 500-1000kms.
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Users browsing this forum: No registered users and 33 guests
