SKDABL wrote:Could you be running too much oil?
My motorbike would die out of its power cus I ran it too rich and burnt the plugs.
Try changing the plugs,
Maybe your battery wires came lose from the terminals or there wasnt enough charge to keep it running.
JT wrote:Gutted man. Check the ECU codes to see if that brings anything up.
Maybe the fuel filter has colapsed or the pump has spat the dummy? You didn't run out of gas?
Check plugs, leads, intake, all the belts etc..
If nothing else is obvious get a compression check done
Lanius wrote:Possibly ... and I hope not ... the cambelt? Sounds like what happened to a honda I had years ago. Just died while driving, then wouldn't start at all.
Good luck getting it sorted.
Lanius wrote:Soz ... missed what you said about having had the cambelt already done.
My bad.
rollaholic wrote:was this the same mechanic who replaced the cambelt last time and left the crank pulley loose?
kingcorolla wrote:Id say the guy that did your cambelt balls'd it up buy not Locktite-ing the pulley bolt. Its his fault.
