Pays not to listen to the lady at the front desk for quotes
blitza wrote:timing belt, $39.60 idler sub assy, $48.40. There is a toyota spec procedure for testing the serviceability of the hydraulic tensioner, so you shouldn't need to buy one of them, there is another idler bearing, but this is avaliable commercially, for $20 exact same part numbers, you just need to reuse the sleeve. There was no need to replace my water pump, as it was all mint.
so I'm not sure where $230 parts came from.....
Inane wrote: $64 - $80+ for spark plugs
Users browsing this forum: No registered users and 33 guests
