fuel/boost cut on turbo SW20
Postby GTSMR2TURBO » Fri Oct 01, 2004 8:50 pm
how many lb's of boost before you hit the fuel cut ???
Current Ride - 1993 GTS MR2 (K&n pod, HKS bov, Toms Kit)
GTSMR2TURBO
Postby Dell'Orto » Fri Oct 01, 2004 9:19 pm
12.5psi
Postby Al » Fri Oct 01, 2004 9:51 pm
Also, to disable the boost cut just pull the hose off the bottom of the boost pressure sensor (next to the grey box labelled diagnostic) and plug the hose up leaving the sensor open to the air
Al
Postby GTSMR2TURBO » Sat Oct 02, 2004 7:47 pm
So wat do they boost as standard ???
GTSMR2TURBO
Postby Al » Sat Oct 02, 2004 8:59 pm
Standard they are t/vsv controlled from 7->11.8psi
usually you should run 10-11ish
optimal conditions (up to temp, good quality fuel and cold intake air) will net max boost of 11.8
Al
Postby lazarus » Sun Oct 03, 2004 2:24 am
Ok noob questions;D
whats t/vsv???
lazarus
Postby Al » Sun Oct 03, 2004 2:47 am
turbo - variable solenoid valve
under optimal conditions it opens and bleeds air away from the actuator, so the turbo has to work harder to fix this 'leak' so it raises boost 3-4psi or so
its a factory boost controller
Al
