Turboed 4AGE
Postby EVLGTZ » Thu Sep 30, 2004 10:36 am
Mr Revhead wrote:hmm reading his sig i can see why hes got so many blown pistons! :lol:
haha those were from the early stock ecu days.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Gearbox
Postby CAMB01 » Thu Sep 30, 2004 9:06 pm
Would an LSD gearbox from a 4AGZE stand up to about 250hp?
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Re: Gearbox
Postby EVLGTZ » Thu Sep 30, 2004 9:46 pm
CAMB01 wrote:Would an LSD gearbox from a 4AGZE stand up to about 250hp?
easy, mines coping with 250hp plus at the wheels, no issues.
EVLGTZ
EVLGTZ
pumps
Postby CAMB01 » Sat Oct 02, 2004 11:08 pm
As i am putting this engine into an import AE92, i am removing the air-con, but will i have to remove the power steering as well? Coz i'm thinking the pump might get in the way. A mate suggested i relocate to the other side of the block, like on the supercharger, but i would have to change pumps, get a different bracket, and change hoses. This is all just too much hassle to me, so i was thinking of removing it if i couldn't have it.
CAMB01
Re: pumps
Postby Dr-X » Sun Oct 03, 2004 10:59 am
CAMB01 wrote:As i am putting this engine into an import AE92, i am removing the air-con, but will i have to remove the power steering as well? Coz i'm thinking the pump might get in the way. A mate suggested i relocate to the other side of the block, like on the supercharger, but i would have to change pumps, get a different bracket, and change hoses. This is all just too much hassle to me, so i was thinking of removing it if i couldn't have it.
You should be able to fit it all. And believe me, moving your p/s pump is a lot less hassle than removing your p/s all together. Not to mention cheaper.
Dr-X
P/S
Postby CAMB01 » Sun Oct 03, 2004 10:28 pm
I've decided to go to strong arm steering. I've got a mate whos good at removing things like that, he said it'll be pretty easy. Just gotta get ma hands on a steering rack. Can i use any old steering rack of does it have to be one from a NZ made GT corolla?
CAMB01
T-VIS
Postby CAMB01 » Wed Oct 06, 2004 10:27 pm
Anyone know how the T-VIS will go when the turbo starts boosting?
Don't really want to take it out it'll cause too much lag. Is there a way of changing its operation?
CAMB01
Postby Zak » Wed Oct 06, 2004 11:02 pm
I think you will have to take it out, as it's vacuum operated and if your boosting there an't gonna be any vacuum :wink:
Zak
Postby matt dunn » Wed Oct 06, 2004 11:19 pm
Zak wrote:I think you will have to take it out, as it's vacuum operated and if your boosting there an't gonna be any vacuum :wink:
But there's no vacuum when you have your foot hard down either........???
They have a vacuum tank/resovior to hold vacuum to run them so it will still work ok as long as the one way valve still works.
Matt
Re: T-VIS
Postby EVLGTZ » Thu Oct 07, 2004 8:04 am
CAMB01 wrote:Anyone know how the T-VIS will go when the turbo starts boosting?
keep it in there, works fine.
EVLGTZ
EVLGTZ
Postby Drifter4ag » Thu Oct 07, 2004 7:43 pm
vaccum closes it
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
