To v8 a hilux
Postby Stu- » Wed Oct 06, 2004 5:18 pm
Another workshop with Hilux 1uz conversion experience is MC Racing/A1 Turbos. Damian has done this conversion many many times and also has a mid mounted 1uz in his rally car. Give him a buz if your after pricing and or information. Drop my name in if you want, might help, but just don't mention all the beer of his I reguarly drink on a friday afternoons :D
MCR
444 3489
Contact :: Damian.
Project Thread
Stu-
Postby Rollux » Thu Oct 07, 2004 12:57 pm
TruenoBoy wrote:Would of been a cool surf :D How did you end up breaking so many axels? was the 302 worked at all? what did you use it for 4wding or just street? Launching hard all the time ? :wink:
Just curious to whether a 1uz-fe would cause chronic axel breakage or not. 4wd have anything to do with it?
Fuel consumption I am guessing wouldnt have helped by being and older carby engine and bigger engine capacity.
My next question would be brakes dont think the standard hilux ones would be sufficient is there any rotors, calipers or even hubs I could swap over from another toyota to help out in stopping the beast? I think I would like to look at having disc brakes all round. And maybe twin piston calipers up front or even all round.
My Surf was 4wd, and I used it a couple of times off road. Most of the axle breakage was abuse ie Launching at 3000rpm with 31x10.5R15 tyres etc. The engine was stock, just a 4 barrel carb, hence the fuel usage and flames. And 2200kg of iron to shift.
As for brakes, if you are going 4WD, the 4 piston front calipers are plenty sufficient, esp with metallic pads. I passed the braking test at 130kph, when it's supposed to be done at 100kph (speedo was way out with the tyres)
Have fun and let me have a drive when you've finished!
2002 Allex RS180 6 Speed
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Rollux
Postby TruenoBoy » Thu Oct 07, 2004 10:17 pm
So the front calipers off a surf are 4 piston? im guessing the same off the 4wd hilux's ?
Sounds like a good idea, will look into discs all round aswell though.
Aslo anyone know what sort of milage You would get out of a pretty much stock 1uz-fe in a 2wd hilux? or even what sort of milage a soarer or ls400 or crown makes? and what sort of weights are they? to compare weight to fuel economy.
TruenoBoy
