Very cheap or FREE mods/things to do to ur car
Postby THA SHZ » Sat Oct 09, 2004 12:23 pm
Make a bodykit for your car out of cardboard for extra downforce :lol:
THA SHZ
Postby WELL » Wed Oct 13, 2004 12:29 am
go to buy a white markerpen and just write down a big " 11.3" or "10.2" on ur side window :twisted:
trueno 86.
WELL
Postby rollaholic » Wed Oct 13, 2004 7:26 am
WELL wrote:go to buy a white markerpen and just write down a big " 11.3" or "10.2" on ur side window :twisted:
now THATS what i call a value for money performance mod ;)
Postby thaphatty » Wed Oct 13, 2004 10:05 am
remove springs, good for a laugh in any car
thaphatty
Postby Dr-X » Wed Oct 13, 2004 10:37 am
Get some Simple Green, coat your engine bay and hose off, finish by detailing with some silicon spray (not recomended) or tyre shine (good stuff, eg meguires gel)
Buy some 'paint on' type tyre shine, and paint over all old trim for a ncie new black look.
Buy some black spray paint, and do some detailing that most people dont bother with, but can make a big difference. Eg, remove wheels, clean wheel wells, and paint them black. Paint brake calipers/drums black. Paint struts black (unless they're already good looking aftermarket ones, obviously).
New windscreen wipers.
Polish headlights (plastic polish, or even better metal polish)
Buy a pastry brush, and use it to detail the interior. It works wonders getting all that dust out of the air vents, and other hard to work places
Dr-X
Postby [intrcool] » Wed Oct 13, 2004 11:43 am
i took off my mug flaps.. makes the car look a little better :)
if ur real bored, go to warehouse and get a amp kit and wire up your car to fit an amp one day... (you learn quite a bit, if u havent done that sort of thing before)
yea, perhaps detail the interior plastic bits a different colour...
i like the make your own short shifter idea.. been wanting to do that for a while.. just need a tool to rethread the stick when i do it...
buy tint and tint ur car
Paint eyelids on your front lights.
if your looking for the manurewa / scummy rotorua look, put ur mums (or sisters) panty hose over your rear lights....
relocate your number plate for "better air flow to the radiator"
Debadge your car
cant think of any more...
[intrcool]
Postby strap-on » Wed Oct 13, 2004 7:20 pm
hahahahahahah quite a few inetresting points there, but theres a few things i must correct.
NEVER wash ur car with HOT water, cold and soapy is the best, hot strips of the wax.
like dr-x said doing inside ur gaurds is a good one, just get some satin-black paint, and do in there,
if u are giving ur car a less thorough wash:
startw ith spraying the wheels with degreaser, (or so acid wheel cleaner if ur mags are NOT painted), give it a brush round, then waterblast off, while there waterblast under the gaurds ( mayb spray under there with degreaser as well),
despite wat people say it is totally cool to spray under your hood with degreaser, and then water blast off, just be a bit carefull round the dizzy and fuse box, ( ie dont pointw ater directly at it) then spray siocone everywhere and wipe off.
when u wash your car, always wet it first, then suds and rub, then hose off, then chamois. when u chamois, open up the doors and do down the door jams as well.
wax, is wax, the shine depends on how much polish u put underneath and much wax u put on top,
any kind of moulding will come up very good, weith nething silcone, try getting a rag, soaking it with silocone then rubbing it in, then wipe off with a clean rag
that goes for doing ur interior as well, dont use those wipes they are crap, get some good v and r (vynal and rubber cleaner) soak it in a rag, then wipe the dash over with it, once again nething silcone based is good.
thats ll itcan think of that uc an do at home without teh stuff i have at work, but if u have any car care questions pm me cos i am a car groomer
strap-on
Postby Silent Knight » Wed Oct 13, 2004 7:26 pm
remove your actuator hose :lol: :lol: :lol:
Silent Knight
Postby mr30% » Wed Oct 13, 2004 11:29 pm
kick the crap out of your front/rear mud flaps/inner gardes %&*(cant spell) 4kilos+of mud fell out remove all old pie bags/kfc/makds crap+2x 12v batts saved 15+kilos car smells better and i can now see the floor best $30 mod timeing up 4/5 degrees+avgas %^&# still cant spell
2 x 81 starlets/parts 2 x84 starlets ee82 ae82 1 x85 aw11 nz new 1 x84 aw11/parts 1 xae101
mr30%
Postby mr30% » Wed Oct 13, 2004 11:46 pm
add to last post make marks on the end plate of your dizzi for 91 96 98 avgas my blue top will run 10 degrees on91 and i go up +2 for each change of fuel keep a12mm ring handy and you can set it to suit better than detonation/ecu retard
mr30%
Postby Pies » Thu Oct 14, 2004 6:11 pm
masturbate into your fuel tank. the high octane rating of semen gives your car that extra boost it needs to over take that suzuki swift infront of you ;)
Current Rides:
Pies
Postby strap-on » Thu Oct 14, 2004 6:22 pm
pies wrote:masturbate into your fuel tank. the high octane rating of semen gives your car that extra boost it needs to over take that suzuki swift infront of you ;)
so THATS your secret, i bet thats how the pros like ronnie lim and fiddy cent do it rite?
strap-on
Postby Muzzie » Fri Oct 15, 2004 2:12 pm
I did the eyelids thing on my Carina when I had it - using electrical tape. Didn't look too bad either...........
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby malc » Fri Oct 15, 2004 3:18 pm
I dont know if anyone has mentioned this already but anyway
BUY SOME MOTOR UP or X1R!!!, IT WORKS!!
its fairly cheap and you notice quite a power gain straight away.
I was amazed when I put some in my ae92, it was actually quite cool.
I think it loses its effect over a longer period of time
but it is an instant power up.
I didnt try any of the fuel system cleaner or anything like that, but i would imagine if you used all the products it would be sweet as a nut.
malc
Postby levin_it_large » Sat Oct 16, 2004 8:49 am
i thort all that motor up stuff was worse rather than better for ur engine, i've heard of a few complaints with it
levin_it_large
Postby Dr-X » Sat Oct 16, 2004 12:10 pm
Hate to tell ya dude, but that looks like shit.
Dr-X
Postby Lloyd » Sat Oct 16, 2004 2:05 pm
ras kongo wrote:its fairly cheap and you notice quite a power gain straight away.
Cant say I noticed a damn thing. And theres probably a reason why there was a court case and they aren't allowed to sell it in the States anymore ;)
And yeah Mussie... not good aye. If its a white car it need white lids
Postby Muzzie » Sat Oct 16, 2004 5:27 pm
Dr-X wrote:
Muzzie wrote:
I did the eyelids thing on my Carina when I had it - using electrical tape. Didn't look too bad either........... from a distance
Hate to tell ya dude, but that looks like sh*t.
Yeah it does close up, but I had more than 1 person ask me about it - from a distance it looked cool, but if you looked closely you could see it was crud.
Muzzie
Regular Poster
Postby Muzzie » Sat Oct 16, 2004 5:29 pm
Not to mention the fact I was 15 and a half with no job....
I think thats a reasonble excuse :wink:
Muzzie
Regular Poster
Postby [intrcool] » Tue Oct 19, 2004 10:20 am
man i didnt think someone would actually do something i suggested..
i painted my drums silver on the weekend.. not the right color.. im gna paint them green maybe this weekend.. will go better with the gold color of the body.. and do the calipers too..
will post a pic after its all done
[intrcool]
Users browsing this forum: Bing [Bot] and 40 guests
