Which bulbs for which car?
Postby UTERUS » Fri Oct 22, 2004 3:17 pm
I have an 88 hilux and i was wondering what headlight bulbs they take.
Also while im at it, what headlight/spotlight bulbs do other toyotas take?
Cheers,
Simon
UTERUS
Postby Just_Juzz » Fri Oct 22, 2004 4:00 pm
Mine takes the standard 3 pin coniguration. 12v, P43T.
Not to sure what the hilux takes. But most cars take this type in their headlight.
My old mans 1994 Hilux takes these as well.
Current Ride: 1998 Caldina GT
Me, me, me, me.....
Just_Juzz
Postby ee904age » Fri Oct 22, 2004 10:27 pm
I could be wrong but dont hilux's of that era take a 2BX sealed beam??? I may have been converted to semi sealed, in which case it would take an H4 bulb.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby TWSTD » Sun Oct 24, 2004 9:14 am
theres not such thing as "standard 3 pin configuration"
Many ancient cars incl older toyota vans use sealed beam as suggested. Many older cars use H4 bulbs. Many newer toyotas seem to use H7's and H3 for spotlights - altho this does vary as ST20# celicas take HB4 for example and others utilise H1, H3 and all sorts of other configurtions.
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby ROBODISCO_20v » Sun Oct 24, 2004 8:50 pm
Yep the hilux will use 2bx sealed beam units. You can get crystal (bling bling) ones fro Braxton lights or any repco/appco. They're semi sealed to so you can put blue/white H4 bulbs in them to give it that euro look.
And as for there being a standard 3 pin configuration. YES there is. It is a H4 bulb. Which most car still use. If you went into a parts shop and asked for a standard head light buld thats what they would give you.
ROBODISCO_20v
Postby nobody » Mon Oct 25, 2004 12:20 pm
This site has some good info and pics on the different types of bulbs most cars use: http://www.susquehanna.com/susq/hella/bulb_styles.htm
nobody
