ive also been told to use a 3 core radiator as opposed to a 2 core radiator (which is what the one of the 3K is)...
Stealer Of Souls wrote:Avoid an Auto radiator.
I think that small difference in internal capacity makes my 4A a little tempermental with temp... See if I turn my heater to hot then I never overheat, turn it to cold, start overheating if I drive long enough...
Just a theory...
NZ_AE86 wrote:Your 3k radiator will work well but your plumbing might be easier if you get one with the pipes on the correct side.![]()
Factory 4AGE Radiator works fine for high Hp 4AGE's.
