1598cc wrote:sweet.. sounds good.. aftermarket ecu would be best, but if i can get away with it on stock, ill choose that route
1598cc wrote:nice.
having no lsd doesnt mean 1 wheel will just spin.. my old civic had no lsd but generally on the strip itd spin 2.
thats a good trap speed tho. theres an old version link on trademe for sale.. that shuld do the trick for the fuel/ignition side of things.
Tukumi wrote:I did my 12.5@109 on 15psi but it was a 1.82 60ft time that gave me the time really.
Im runing a Link LEM v5 in my levin, I help Link a bit testing there products and giving feedback which can be a bit of a pain sometimes as im forever changing to diferent computer setups and have to retune alot, so theres not alot of point getting dyno tunes all the time so we do all the tunning on the road (in controlled circumstances) with a wideband o2 meter and knock gauge. We seem to get good results, but im keen to get it on the dyno next week and have it tuned for the next meeting at ruapuna on the 9th.
Tukumi wrote:Time for my two cents.
I was running a t3/t4 on my 4agte which worked ok got me 250hp@17psi atw but no matter what boost or fuel curve i would run 250hp was the max i could get. After talking to a few people i decided to check my turbine backpressure and found at 15psi i was getting up to 30psi in the turbine housing(or exaust manifold) so the gasses couldnt get out fast enough. The reason behind this was I was running a turbonetics super to4e compressor side which its operating speed was arond 85,000rpm and the turbine was standard t3 which is meant to spin at around 140,000rpm, so the speed of my turbo was somewhere around 100,000rpm which meant the t3 exaust wheel could spin fast enough to get the gases out.
So yesterday i was on a mission to sort out the problem, I talked to a couple of guys overseas with big hp 4agtes (eg400hp upwards), They were all running full to4 turbos. So i did some more ringing around and managed to find a Hks to4 exaust housing that took the smallest to4 wheel being O Trim and it had a A/R of 0.40. I bought it yesterday morning for $200 and it was even hpc coated. I got the right wheel off a mate to suit built the turbo modified my manifold, made a new downpipe and got it all done by 6pm.
All i can say so far is that this turbo spools alot harder than my old setup, i get 15psi by 3500rpm, but best of all at 15psi im only getting 17psi in the turbine. and it revs hard to the limiter at 8000rpm, im getting wheelspin in 3rd where i never used to, and its got rid of a fair bit of detonation that it was getting from being to restricted. It will be back on the dyno next week so ill let you know how it goes.
Hope this helps people with t3/t4 setups.
Difference in wheel size, T3 on left O Trim To4 right
My wee bit of Bling
Phil
terrytuffguy wrote:
p.s. What is your timing at 15psi?
