UH OH i think...help needed
Postby DEVILE » Wed Dec 29, 2004 2:41 pm
we have a ae82 fxgt....i drained the coolant system/flushed it etc...it had overheated once to 3/4 temp but never into red...now after i filled it and took it for a drive there is white froth in the top of the radiator (looks like when you add degergent to sink of water)...there was a bit of oil in the water i drained but no water in the oil,no water at all coming out the exhaust....blown headgasket or something else?????? 8O 8O
previous :1980 DX rolla
ae101 fxgt
GTT caldina
current: bighorn
project: ae.. fxgtt
http://toyspeed.blakjak.net/profiles/profile.php?id=830
T caldi
http://genesis-race-division.com/devile/
DEVILE
Postby CozmoNz » Wed Dec 29, 2004 3:33 pm
Im guessing blown head gasket, i might be wrong though :)
Rayne For President!
CozmoNz
Postby Bling » Wed Dec 29, 2004 3:47 pm
CozmoNz wrote:Im guessing blown head gasket, i might be wrong though :)
he asked for help, not your guess :roll:
Re: UH OH i think...help needed
Postby vvega » Wed Dec 29, 2004 3:56 pm
DEVILE wrote:we have a ae82 fxgt....i drained the coolant system/flushed it etc...it had overheated once to 3/4 temp but never into red...now after i filled it and took it for a drive there is white froth in the top of the radiator (looks like when you add degergent to sink of water)...there was a bit of oil in the water i drained but no water in the oil,no water at all coming out the exhaust....blown headgasket or something else?????? 8O 8O
if its oil you have a head gasket issue unless you filled it from a old oil container :S
as for the frothing
well that can be jaust all the air purging from the system.im gathering you have just filled it up and without the right tool will take a little bit to get rid of it all throught the system
dont lose faith yet
just let it idle with the cap off for 15 mins
keeping ya eye on the water
you cabn come round if ya want and i could have a look (im in te awamutu)
but thats up to you :d
v
vvega
Postby DEVILE » Wed Dec 29, 2004 3:58 pm
I'll be back in 15 mins :wink: :wink:
ae101 fxgt
GTT caldina
current: bighorn
project: ae.. fxgtt
T caldi
DEVILE
Postby vvega » Wed Dec 29, 2004 4:10 pm
im just heading over to hams to pick up a head and block
027 632 9521
be over there till 530 ish so give me a yell if ya want
v
vvega
Postby DEVILE » Wed Dec 29, 2004 4:12 pm
Thanks but we are in Waihi now :( It is looking like its the Head Gasket :(
ae101 fxgt
GTT caldina
current: bighorn
project: ae.. fxgtt
T caldi
DEVILE
Postby vvega » Wed Dec 29, 2004 4:14 pm
DEVILE wrote:Thanks but we are in Waihi now :( It is looking like its the Head Gasket :(
gutted
oh well eazy fix :D
v
vvega
Postby DEVILE » Wed Dec 29, 2004 4:18 pm
Yip looking very much like the head gasket. We did the 15 min test still has bubbles then when reved turns to foam :(
RIP the FXGT :(
ae101 fxgt
GTT caldina
current: bighorn
project: ae.. fxgtt
T caldi
DEVILE
Postby Mr Revhead » Wed Dec 29, 2004 5:17 pm
not rip, think of it as an opertunity!!
perfect excuse for a full rebuild with cams high comp pistons etc etc :lol:
its not the end of the world, a new h/g is only $60 odd. coupla mates, a few beers and your done in an arvo. 8)
Postby evil_si » Sat Jan 01, 2005 9:09 am
you say you did a flush, did you use a chemical type?
in the past ive encounted symtoms like yours, when the chemical flush wasnt flushed properly with fresh water after wards.
for instant when i do a flush
i drain coolant
add flushing chemical, and fresh water
run for 30mins, dump flush / water mix
fill with fresh water, run for 30 mins
dump water, refill with fresh water, run for a further 30 mins, dump and fill with new coolant
evil_si
