Anyone using aftermarket cams in their 4age
Postby ants_ae92 » Thu Jan 06, 2005 4:55 pm
I was wondering who has aftermarket cams in their 4age 16v? What setups are you guys running, eg stock valves and ecu, or aftermarket computer?
I was looking at 272deg or possibly 264deg but I want to run stock ecu?
Any Ideas guys. Possibly going through kelfords as well.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby RedMist » Thu Jan 06, 2005 8:22 pm
In my 16 valve I run...
Stock valves with modified stem.
Link LEM 4
304 degree 415 thou lift cams. From Kelfords, who also created the shim under bucket solution.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby vvega » Thu Jan 06, 2005 8:37 pm
RedMist wrote:In my 16 valve I run...
Link LEM 4
there is also a factory drop in item as well that will do the conversion for you :D
v
vvega
Postby CAMB01 » Thu Jan 06, 2005 11:36 pm
I'm running a high performance road grind from Kiwicams with Crow
Cams heavy duty valve springs, in a ported and polished head (16v Big Port). Running standard ECU at the mo, but have an adjustable FPR and higher capacity injectors (looking to just get the ECU chipped).
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby CAMB01 » Fri Jan 07, 2005 6:46 pm
Kiwicams is in Palmerston North, 21 Domain Street
CAMB01
Postby soopachargen » Sun Jan 09, 2005 11:28 am
Another option to the OEM shims are the one that come is TOyota Yaris 1.0 engine which i believe are a direct fit/upgrade to ours since they´re one piece and theyre lighter and are available in many sizes to adjust the valves.
i got this from somewhere on club4age, its in regard to replacing shim buckets... cant remember the whole story right now but they are a replacement for shims or something (correct me if i'm wrong) for running a high lift camshaft in a 4age, i believe there is a really good article in the tech section there
When in doubt, down and out.
soopachargen
Postby ChaosAD » Sun Jan 09, 2005 1:23 pm
I also looked into this. From memory I think it was about $35 a piece which works out to be $560ish for all 16. Then if you needed to change the clearances youd have to change the whole bucket.
You'd want to check prices from a dealer first though
ChaosAD
Postby ee904age » Sun Jan 09, 2005 6:16 pm
I think Mr Revhead does those one piece bucket/shims for bout $6ish ea.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby ChaosAD » Sun Jan 09, 2005 6:44 pm
8O Thats cheaper than just the 16v shims!
ChaosAD
Postby Mr Revhead » Sun Jan 09, 2005 8:33 pm
the cheap ones require maching to fit...
the 1nz ones (drop in replacement) are closer to the price above....
but its been a while since i checked
Postby soopachargen » Tue Jan 11, 2005 7:54 pm
hahaha, ive been quoted...
this may not be a big thing for you guys but this is the first time that i have been quoted on toyspeed! thank you... i will be here all week...
just kidding...
soopachargen
Postby ChaosAD » Tue Jan 11, 2005 8:24 pm
just kidding...
No worries
ChaosAD
