YeMs wrote:i really dont suggest doing it on your own, u have to make sure the CV is packed properly, make sure it fits properly, make sure u dont break the circlip wen fitting the cv, make sure the circlip is correctly fitted, if u have removed the whole shaft to do the job that wen ur refitting that u dont pinch the axle seal, that your cv ties are done up tight enough to secure the boot so it wont fall off, that every thing is done up tight and fitted properly.
ok, lets go down the list:
CV's packed properly: usually come pre-packed, and pretty simple to do anyway.
Fits properly: Do you think you can tell the difference between the square peg and round peg before you put it in the hole?
Dont break circlip: Cant even figure out how you'd do this
Circlip correctly fitted: If you know what a circlip is (which I hope you do) you'd know why this is just stupid
Dont pinch axle seal: Again, cant figure out how you'd do this
CV Ties done up tight: Can you tighten a screw?
This aint rocket science, guys.
