4age not running, fault codes ?
Postby AE85.6 » Wed Jan 12, 2005 12:49 pm
tried doing a search but couldnt find anything,
just seeing if anyone knows the list of fault codes that cause your check light to come on or knows a link to some where i can look them up,
also if anyone one round aucks has use of a diagnostic computer after hours ???
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby ee904age » Wed Jan 12, 2005 7:29 pm
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby AE85.6 » Thu Jan 13, 2005 9:46 pm
ee904age:
sweet cheers for that man,
dont spose anyone has the use of one of these comps after hours ???
local garage cant check for me till like thurs next week, will try some other garages on sat morning i guess
AE85.6
Postby AE85.6 » Fri Jan 14, 2005 2:21 pm
bump,
or could recomend someone that may be able to look at it sat morning ???
AE85.6
Postby ee904age » Fri Jan 14, 2005 5:13 pm
What do you need the computer for? I dont think it will tell you much more than checking the ECU will.
90 SW20 N/A - Sold
ee904age
Postby matt dunn » Fri Jan 14, 2005 7:08 pm
ee904age wrote:What do you need the computer for? I dont think it will tell you much more than checking the ECU will.
In fact I think you'll find that a diagnostic computer won't even work on an AE86. Too old. Manual codes only.
matt
Postby AE85.6 » Sat Jan 15, 2005 9:59 am
oh ok sorry i dont know much about it i thought id need a diagnostic comp to tell me the error code this is obviously not the case, so whats the correct way to check the ecu then ?
also if the rotor and dizzy cap were fairly crap looking would that be enough to maybe trip the light for the ignition or rpm code ?
cause now car doesnt even start will turn over but when you let go of the key it dies, or if you start it with you foot on the gas it will start and rev but you take you foot of and it dies, i think it might not be lack of fuel i think it could be lack of spark maybe, cause when it was turning over and dying i could smell unburnt petrol, i took the dizzy cap off and scratched up the rotor and bits inside the cap and it fired up like nothing was wrong drove all the way to my olds and didnt miss a beat until just about arriving but it only coughed once and again flashed the light,
AE85.6
Postby AE85.6 » Sat Jan 15, 2005 10:25 am
also ill have to check when i get home but i dont think ive even looked for the ecu since ive picked up this levin, where are they normally in AE's ? under one of the seats or under the dash or somewhere ?
AE85.6
Postby ee904age » Sat Jan 15, 2005 12:40 pm
You dont need to find the Ecu to get the codes.
There will be a two pin diagnostic plug in the engine bay (yellow plug with black rubber cover over it).
Short the two pins out and turn the key to on.
Check the number of flashes and match up with the link I gave you.
They will read as follows:
13 will be *...***...*...*** etc where * is a flash
If there is more than one code it goes
13 & 17 will be *...***.......*...*******.........*...***.........*...*******
Be sure to reset the ecu by disconnecting the batt for a few minutes before and after.
90 SW20 N/A - Sold
ee904age
Postby ee904age » Sat Jan 15, 2005 12:42 pm
Oh, and if you get a constand flas like *...*...*...*...*etc it is not reporting any faults.
Shay
90 SW20 N/A - Sold
ee904age
Postby AE85.6 » Sat Jan 15, 2005 1:04 pm
ah ok sweet man cheers,
ok i found where the main loom comes thru the firewall there is a bunch of 4 yellow plugs coming off it, 3 round 1 square, 2 of the round ones are small, one with black rubber cover and one without, the one with the rubber cover on it only has one slot in it and the one slightly bigger has 2 slots, is the one with 2 slots the one to short out by bridging cause the one with the rubber cover on it only has the one slot, however the one with two slots cant fit the rubber cover so it must be the smaller one ???
AE85.6
Postby AE85.6 » Sat Jan 15, 2005 1:11 pm
ah ok yup its the one with two slots rest must have just lost rubber caps, ill reset ecu then do again and try see what code it says,
AE85.6
Postby AE85.6 » Sat Jan 15, 2005 1:25 pm
ok after reseting the ecu it flashed 11 times pause then flashed 11 times again, but i tried starting the car got it running for a short time coughed and spluttered flashed the light and died, so i tried it again then and it flahes 3 times pauses then flahes 11 times, not sire what that code relates too thou
AE85.6
Postby AE85.6 » Sat Jan 15, 2005 2:40 pm
hmmm just checked spark again and there isnt any man i dunno whats going on now ay, so what would be stopping the spark now coil or ???
AE85.6
Postby ee904age » Sat Jan 15, 2005 5:23 pm
Do you have a multimeter? Check that you have power at the coil and igniter. Assuming your car has had a transplant, did you use the complete AE86 loom or has it been modified to suit?
I dont have my manual on me but someone may know how to check the resistance through the coil and igniter.
90 SW20 N/A - Sold
ee904age
