Redtop 4age oil pressure
Postby KwS » Thu Jan 20, 2005 11:34 pm
Yello.
Mates for an AE92 levin. Redtop 4age.
Just a quick question, what is the normal range for the oil pressure to read on the oil press gauge at like 600-700rpm (idle)? at the moment it reads like quater on the guage. Is that normal or is something wrong?
KwS
Postby Zak » Thu Jan 20, 2005 11:47 pm
Is the car hot or cold? I would be a tad bit worried if it was cold and that low. Does it go up when driving? As that is more important than idle pressure.
Zak
Postby KwS » Thu Jan 20, 2005 11:58 pm
that was when the car was up to normal temp.
yes, the pressure goes upto roughly half when driving normally.
KwS
Postby Zak » Fri Jan 21, 2005 12:13 am
Well, thats not too bad then, my redtop sat at about 1/3 on idle when warmed up, and that was a fresh motor. What does the gauge sit at when the engine is cold? That might be a better indication of whether some thing is wrong or not.
Zak
Postby KwS » Fri Jan 21, 2005 12:25 am
yeah, i dont know what it is when cold. ill get him to find out tomorrow and ill get back to you on that one.
KwS
Postby KwS » Fri Jan 21, 2005 4:27 pm
the pressure is roughly at half when started cold.
KwS
Postby Zak » Fri Jan 21, 2005 4:29 pm
That sounds about right, it's all good then.
Zak
Postby CAMB01 » Fri Jan 21, 2005 11:29 pm
That doesn't really sound good to me, i think the problem is the sender unit located on the left side of the block, under the power steering pump.
Over time they start to give inaccurate readings, mine had a similar problem, so i replaced it with a brand spanker, reads good now.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
