3sgte Map Sensor??? Need to help to clarfy
Postby Mr XXX » Wed Jan 26, 2005 7:15 pm
Hey Guys
I have a sensor sitting here and am trying to find out what ebgine and its purpose it is for
So here are the details
SENSOR ASSY, TURBO PRESSURE < This makes me assume its a map sensor. Has a vacuum line hanging off the side of it, and has an oval 3 pin Plug.
Part Numbers Are:
TOYOTA
89420-17030
Also has
100798-2012
And is cranking a whole 5v's
Cheers for any help anyone can shead on the matter
Allan
Seedy Al's Chop Shop
Current Rides - 7-age At141 Corona, 81 kE70 Sedan, 1970 MS55 Crown, 72 B1600, ke25 Corolla x 2, Suzuki Carry Van x2, 910 BLuebird, 4age KP starlet
My Life Is a F*cken Project
Suck a Dx Chris
Mr XXX
Postby Chickenman » Wed Jan 26, 2005 7:18 pm
Well...
Mines a GenII 3sgte (AFM) and the map sensor is primarily for the onboard boost gauge. I'm not sure if it has anything to do with boost cut etc :?:
Baby Jesus
Chickenman
I Am The Walrus!
Postby Al » Wed Jan 26, 2005 7:35 pm
Yep its a 3sgte one. Controls the stock boost gauge and fuel cut at 12.5psi
Al
Postby Twolitre » Wed Jan 26, 2005 7:41 pm
Chickenman's onto it, if it's off a Gen II 3sgte then it's for the boost gauge and the fuel cut, the AFM is the primary airflow device but on a Gen III engine only the map sensor is used.
Some fantastic information can be obtained on the following page:
http://gtfour.supras.org.nz/mapsensor.htm
Twolitre
Postby Chickenman » Wed Jan 26, 2005 7:53 pm
Twolitre wrote:Chickenman's onto it,
I deny that vehemently :o
Baby Jesus
Chickenman
I Am The Walrus!
