6 month old springs sag?
Postby RS13 » Tue Feb 01, 2005 1:05 am
How would you rate the ride quality with Dobis', as compared to Kings etc?
RS13
Postby snwtoy » Tue Feb 01, 2005 8:57 am
If you're asking me, I have no way of comparing them. I had king superlows in my 82 Celica XX, but it wasn't very low. From memory the ride was still pretty comfortable (14" wheels) - but this was 10 years ago.
The caldina sure is pretty bumpy with these springs (dobi's I'm guessing), and will probably get a bit harsher with the 18s on it.
snwtoy
Postby aesc » Tue Feb 01, 2005 10:21 am
RS13 wrote:How would you rate the ride quality with Dobis', as compared to Kings etc?
My little bro has Dobi super lows in his 92 Laser TX3, real good springs in my opinion, gave it an even 50mm drop (which is v. rare! - esp in Fr engine car) and the ride is very good, pretty firm but not harsh at all. Doesnt handle that well but thats to be expected with any SL springs i suppose
EX AE101 owner
2013 Ford Focus ST
aesc
Postby atmosports » Tue Feb 01, 2005 6:16 pm
3mm difference is not worth worrying about, you could always shim it up 3mm if you wanted to. Else you could piss round moving stuff & trying to put some of the weight from that corner onto the other side to help even it out, but yeah wouldn't be worried about 3mm.
atmosports
Postby snwtoy » Tue Feb 01, 2005 6:58 pm
Hmm.. just measured again cos it still looks off.
From the top of the rim to the guard it's a 4mm difference.
From the ground to the bottom of the kit in front of the wheel it's a 15mm difference.. grrr.
Maybe I will try swapping the springs over afterall.
snwtoy
Postby Dr-X » Tue Feb 01, 2005 7:07 pm
aesc wrote:My little bro has Dobi super lows
Just FYI - AFAIK, Dobi, Lovells, etc dont do super lows. "Super low" is a kings brand. Some other brands may do different height springs, but they're not "Super lows".
Dr-X
Postby ChaosAD » Tue Feb 01, 2005 8:04 pm
It depends on the particular car. On one dobis are shit and kings are reasonable on another dobis are way better. You cant just compare the brands
ChaosAD
i got jamex
Postby shaggz » Wed Feb 02, 2005 12:40 pm
i got jamex in my 99 rolla wagon and i rate them i think they are wicked ive got a 60mm drop out of using a set of low's wich normally the guys and mag and tyre only see around a 45-50mm drop so im as happy as a pig in a pile of brown slushy
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Postby craigt » Wed Feb 02, 2005 7:55 pm
If you are only after a change of 3mm, go to a wreckers and find a rubber spring seat thats slightly thicker ( if you are using them).
Otherwise put a piece of rubber tube over one end of the spring, this can sometimes be done in place with a spring compressor without removing the strut. Also check what you are measuring off. Your front guards could be 3mm different
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
