Oil in Black Tops
Oil in Black Tops
Postby dotdog » Sun Jan 30, 2005 9:37 pm
Hey all, just about todo my second oil change in my bzr levin, I put castrol magnatec in it last time which seemed to make the lifters a bit nosiey. What sort of oil does everyone else run in there black tops and do they have noisey lifters?
dotdog
Postby Bling » Sun Jan 30, 2005 10:39 pm
i run magnatec currently, doesn't seem to get used as much as other oils, so i'll be sticking with it. :)
Postby vvega » Sun Jan 30, 2005 10:56 pm
hahaah lifters......
hahahahahhaha
hahahahahha
lifters........
hahhaahhahaha
v
vvega
Postby matt dunn » Sun Jan 30, 2005 11:01 pm
vvega wrote:hahaah lifters......
hahahahahhaha
hahahahahha
lifters........
hahhaahhahaha
v
yeah, i was just thinking, what the hell does he mean by lifters???
Not much in there that you can confuse with lifters?
Postby CozmoNz » Mon Jan 31, 2005 12:19 am
hes talking about his pushrods man >.>
just stick some proma in man, stops that noisy pushrod / rocker arm click ;)
I Use titan CFX.. (i think its cfx)... 10w 30 :).
Rayne For President!
CozmoNz
Postby TrouserFxGt » Mon Jan 31, 2005 7:06 am
oh dear.
toyota says a sg-sh multi grade oil.
how cold does it get there?
15-40 will do for most climates though.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby dotdog » Mon Jan 31, 2005 4:55 pm
You know what i mean, dont know what gay black tops have, be it cam follers, rocker arms, hydrolic lifters, i dont know, all i want to know is what oil to put in da pig
dotdog
Postby TrouserFxGt » Mon Jan 31, 2005 6:00 pm
TrouserFxGt wrote:oh dear.
There you go. Thats straight from the Black top service manual.
Buy a reputable brand and change as recomended.
If ya want to feel good about yourself buy a PAO fully synthetic for around $80-100 and change it at 1000k's even thoug it will more than likely last 30,000k's without degrading.
If you want to get fanatical about your oil then I would recomend either redline or amsoil. Get quality filters (oil, fuel, air) and change them every 6 months and get an oil sample analysed ever 10k or so.
H J Simpson.
TrouserFxGt
Postby 10k 20v » Mon Jan 31, 2005 7:39 pm
and use a genuine oil filter 8)
the rattle will be the vvt pulley, very common
and to be helpful they run shim under buckets
also pro-ma won't fix that rattle
10k 20v
Postby dotdog » Mon Jan 31, 2005 8:20 pm
Thanks for that all, and i now know what sort of things my cams run, sweet
dotdog
Postby alastabesta » Mon Jan 31, 2005 9:53 pm
fully senthe didnt do any good on my bk top - it was too thin...
i'm using protec atm, still leaks abit at high end (around 6500rpm to 7000)
2001 Caldina GT-T
alastabesta
Postby CozmoNz » Mon Jan 31, 2005 11:47 pm
alastabesta wrote:fully senthe didnt do any good on my bk top - it was too thin...
how the HELL do you check if it leaks @ 7000rpm?
your buddy revs it to 7 and you see the oil seep out......
with the oil i use i rev it out quite freqnetly (around 7k rpm in 1st and second... up to 8k in 3rd and above..)... and ever since ive changed my oil.... (3-4 months ago)... its gone down to half... but then again, i do give my car alot of shit ^_^.
CozmoNz
Postby Adamal » Tue Feb 01, 2005 12:03 am
Can't get Amsoil in NZ anymore! :cry: :cry: :cry:
Postby alastabesta » Tue Feb 01, 2005 12:13 am
with the oil i use i rev it out quite freqnetly (around 7k rpm in 1st and second... up to 8k in 3rd and above..)... and ever since ive changed my oil.... (3-4 months ago)... its gone down to half... but then again, i do give my car alot of sh*t ^_^.
well u detail the inside of the bonnet so it looks brand spanking new, go out for a test drive and then come back, finds out theres oil residue on the inside of the bonnet again... :cry: but its sweet up to 4000rpm.
2001 Caldina GT-T
alastabesta
Postby smokabitabud » Wed Feb 02, 2005 10:59 am
i have a stupid rattle when the car is idleing as well my mate said it sounds like lifters as well..........ive put some quieting stuff in but that didnt do ne thing......so will putting good oil in fix this or r there ne other ways to fix it
smokabitabud
Postby CozmoNz » Wed Feb 02, 2005 1:04 pm
smokabitabud wrote:i have a stupid rattle when the car is idleing as well my mate said it sounds like lifters as well..........ive put some quieting stuff in but that didnt do ne thing......so will putting good oil in fix this or r there ne other ways to fix it
Lemmie guess... its a 20v >.>
its your vvt cam.... they are just noisy ;) its the way they are.
CozmoNz
Postby ee904age » Wed Feb 02, 2005 6:21 pm
My 16V was rattling at idle, now its a really loud knocking/thumping!
Man I should really change my gearbox :roll: :roll: :roll:
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby BZG Wagon » Sat Feb 05, 2005 11:29 pm
Mine makes the 'ticking sound too' (I thought it was the tappets or a noisy injector - but who knows/cares).
I use magnatec & it seems to be fine (800mls oil to 2000kms - its high consumption but the 20V engine seems to go through shit loads of oil no matter what you put in it). It was 1L per 1000kms with GTX 15/40 before I switched.
BZG Wagon
Postby CozmoNz » Sat Feb 05, 2005 11:33 pm
depends how oftern you ring her out :).
any chance that at above 4k rpm there is enough vac to *suck* the fumes... and any splashing up oil into the intake... thus excess oil usage if you give it enough shit?
CozmoNz
Postby Fuct Munkey » Sun Feb 06, 2005 12:39 am
i kno its off topic, but i just put a new silvertop in my ae101 fxgt and it rattles so much it sounds like a diesel!!! also other probs that need sorting out, but yea, just thought id chuck my own problem in here! :?
Fuct Munkey
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
