Turboing a ae111
Turboing a ae111
Postby smokabitabud » Fri Feb 04, 2005 11:25 am
how much r u looking at to PROPERLY turbo a ae111. my mates turboed his civic and first time round he blew it to bits, thats not what im after. i dont want huge amounts of boost just 8 or 10 pound. do i have to replace the internals etc etc
thanx
smokabitabud
Postby rallymazda » Fri Feb 04, 2005 7:14 pm
6000 plus depending on connections and how much work you do yourself
if you plan to turbo the 4age blacktop yes you will need to stick a 4agze bottom end on
but try using the search engine theres a million topics related to turbo 4ages
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby Mr Revhead » Fri Feb 04, 2005 7:44 pm
you will need to replace the rods and pistons, not nessicarily the whole short block. blacktops and zes can go for similar prices, the challenge is finding a ze. all comes down to if your paying for it all or doing some your self
Postby matt dunn » Fri Feb 04, 2005 11:33 pm
Here is what I would do if I was turboing my AE111.
Pull off the head and sump etc,
Fit NEW toyota AE101 GZE pistons and rings from mr Revhead.
Now rods, Apparantly the blacktop ones are weak, but have no proof either way. for 8psi, i'd use the std one's but you will always want to run more boost, and for the price i'd fit s/h or new silvertop rods.
Bolt it back together with a new headgasket, rods bolts and head studs.
Get an exhaust manifold mead to suit you car and choice of turbo.
You will need a new plenium chamber made too as the split with pressure.
Plumb it all up.
Use the standard loom under the bonnet, unplg the AFM and bin it, and just tape up the wires out of the way.
Wire in a link ECU and get it tuned.
Away you go, all set.
This set up with silvertop rods will run ok up to the limit of the std injectors which i think is around 13 psi.
Everything else should be fine.
no need to upgrade fuel pump's, change blocks, cranks, loom's or gearbox, just leave it all std.
But thats only the way i would do it. Others may have different views.
Matt
Postby TrouserFxGt » Sat Feb 05, 2005 10:17 am
you wont need to ditch the afm as the blacktop ain't got one.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby matt dunn » Sat Feb 05, 2005 1:22 pm
TrouserFxGt wrote:you wont need to ditch the afm as the blacktop ain't got one.
Ahh, yes you are correct.
Users browsing this forum: Bing [Bot] and 23 guests
