event2 wrote:hey i feel my super charger is starting to get a bit worn it hasnt droped in the boost department i jst find that its uses a bit of oil my car has done 176000kms now. soo i was woundering about reconditioning it like getting a seal kit and mayb bush and bearings depending on what they have. im sure bearings or bushes would be easy enough to find just woundering about the seals.
evil_si wrote:well done on finding a bearing that crosses over,
ive tried a few different bearing agents and never had any luck.
the auto clinic in east tamaki rebuild these blowers, and from what i understand machine out the end plates to take a bigger bearing,
which is how i intended to rebuild a blower i was playing around with
FLAWLES wrote:evil_si wrote:well done on finding a bearing that crosses over,
this would be a better idea machining the housings out to fit a bigger bearing " and a better one " like a c3 type bearing
prob be cheeper to
Uhhm, C3 is not better than a normal bearing. C3 simply means 'increased clearance', to allow for expansion in VERY high temperature aplications. In fact it would probably wear out faster than a 'stock bearing' as you say.
