super charger wear
super charger wear
Postby event2 » Mon Feb 07, 2005 11:18 pm
hey i feel my super charger is starting to get a bit worn it hasnt droped in the boost department i jst find that its uses a bit of oil my car has done 176000kms now. soo i was woundering about reconditioning it like getting a seal kit and mayb bush and bearings depending on what they have. im sure bearings or bushes would be easy enough to find just woundering about the seals.
1991 gtz trueno "HELL YEA" 4 sale (sold and i miss it so)
event2
Re: super charger wear
Postby matt dunn » Tue Feb 08, 2005 12:31 am
event2 wrote:hey i feel my super charger is starting to get a bit worn it hasnt droped in the boost department i jst find that its uses a bit of oil my car has done 176000kms now. soo i was woundering about reconditioning it like getting a seal kit and mayb bush and bearings depending on what they have. im sure bearings or bushes would be easy enough to find just woundering about the seals.
The supercharger itself uses oil, or the engine uses oil?
The s/c is really a non servicable item according to the service manuals.
Matt
Postby evil_si » Tue Feb 08, 2005 7:28 am
the genuine bearings are unavailable, in fact there are no bearings of those type , size made any more,
the only way to do it is match a bearing to the shaft, and machine the end plates to take the bigger size bearing,
they are a ball bearing, not a bush as such,
seals are easy enough to come by as they are a fairly common size
evil_si
Postby event2 » Tue Feb 08, 2005 10:34 pm
yea the super charger it self. uses about 50ml every 5000 kms super chager oil. r the seals just like the oil seals in alternators with vacume pumps on the back? i can get them easy enuff
event2
Postby evil_si » Wed Feb 09, 2005 5:45 pm
they are just a lip type oil seal, any were like saeco should be able tyo supply them
evil_si
Postby FLAWLES » Wed Feb 09, 2005 5:50 pm
hate to point it out man...... but you can buy the bearings for the chargers done the home work and found the orginal toyota part numbers then crossed them over to the koyo bearing numbers " whitch i dont have on me now at this moment in time "
pending on were you are like in hamilton or chch go see SMP bearings they are the koyo imports for nz.. but this bearing is not a off the shelf part
and the failer of these bearings is caused by the s/c pulley bearing " same az on a a/c unit " these flog out and causes the drive rotor bearing to chuck its toys out of the sand pit
FLAWLES
Postby ndeany » Thu Feb 10, 2005 1:31 pm
can you not get an engineer to machine it out to fit larger bearings??
ndeany
Postby FLAWLES » Thu Feb 10, 2005 5:22 pm
i spose it would be posible but dont now how the alumium would cope
FLAWLES
Postby evil_si » Thu Feb 10, 2005 7:39 pm
well done on finding a bearing that crosses over,
ive tried a few different bearing agents and never had any luck.
the auto clinic in east tamaki rebuild these blowers, and from what i understand machine out the end plates to take a bigger bearing,
which is how i intended to rebuild a blower i was playing around with
evil_si
Postby ndeany » Fri Feb 11, 2005 8:39 am
do you have any idea what it costs??
ndeany
Postby FLAWLES » Fri Feb 11, 2005 5:05 pm
evil_si wrote:well done on finding a bearing that crosses over,
this would be a better idea machining the housings out to fit a bigger bearing " and a better one " like a c3 type bearing
prob be cheeper to
FLAWLES
Postby ndeany » Mon Feb 14, 2005 12:02 pm
hey anyone had one rebuilt?? What did it cost?? Have you noticed any improvements in performance??
ndeany
Postby vvega » Mon Feb 14, 2005 1:19 pm
prob be cheeper to
is 100-150,000 kms of use not good enough from the stock bearings???
v
vvega
Postby FLAWLES » Mon Feb 14, 2005 5:20 pm
wasnit for me
died at rite on 100-000k
and was only doing 10psi and was just resintly top up " this was my first s/c " not the 2nd :wink:
FLAWLES
Postby Fandango » Tue May 03, 2005 12:19 pm
[/quote]this would be a better idea machining the housings out to fit a bigger bearing " and a better one " like a c3 type bearing
Uhhm, C3 is not better than a normal bearing. C3 simply means 'increased clearance', to allow for expansion in VERY high temperature aplications. In fact it would probably wear out faster than a 'stock bearing' as you say.
8O
Fandango
Postby Fandango » Tue May 03, 2005 12:20 pm
ooops I quoted myself, what a knob.
Fandango
