4efe 4efte differences
Postby MacrosSiR » Sun Feb 13, 2005 11:17 am
Hey guys, my girl has a 1997 Corolla 2 lime 4efe. Just wanting to research how easy it would be to turbocharge.
How much of an internal difference is it between the 4efe and the 4efte. Just the pistons? Or will connecting rods and other bits need to go?
Would be using the standard startlet turbo and intercooler.
MacrosSiR
Postby Stu- » Mon Feb 14, 2005 8:37 pm
Guys in oz run turbo setups on internally stock 4efe's with GOOD TUNES. As long as your conservative with boost I'd expect you not to have any reliability problems.
Project Thread
Stu-
Postby MacrosSiR » Wed Feb 16, 2005 9:51 am
What if I wanted to use the standard 4efte turbo kit and ecu?
MacrosSiR
Postby Stu- » Wed Feb 16, 2005 8:45 pm
Should be fine as long you stick under 13psi.
Project Thread
Stu-
Postby the fallen303 » Wed Feb 16, 2005 9:33 pm
is it possible to do the same as this but with a 5efe 1500 as the base to start with? what would be needed to swap over? obviously the ecu, turbo and exhaust side, but what about the inlet side? injectors, manifold, throttle body, etc. would these need to be swapped as well?
true house of JZ
Stay true to the origin
the fallen303
Postby Stu- » Wed Feb 16, 2005 10:22 pm
Injectors yes, rest no. You are dealing with higher compression so it may pay to knock the timing back a bit if your using the stock ecu.
Project Thread
Stu-
Postby MacrosSiR » Sat Feb 19, 2005 12:47 pm
Does anyone know how high the compression is on the 4efe?
MacrosSiR
Postby CozmoNz » Sat Feb 19, 2005 1:34 pm
9.6:1
Rayne For President!
CozmoNz
Postby MacrosSiR » Mon Feb 21, 2005 8:52 am
hmm no wonder it works fine on 91 octane
cheers.
MacrosSiR
Postby summin » Tue Feb 22, 2005 9:24 pm
the fallen303 wrote:is it possible to do the same as this but with a 5efe 1500 as the base to start with? what would be needed to swap over? obviously the ecu, turbo and exhaust side, but what about the inlet side? injectors, manifold, throttle body, etc. would these need to be swapped as well?
Try gettin a hold of gtpornstar, think he's got something like that running in his starlet. You'll definitely need to keep the boost way down, and duno what ecu you'll use for it either without going aftermarket...
summin
