Hole in the firewall...
Postby Willdat? » Wed Feb 16, 2005 10:40 pm
I asked this on the ass end of my last post but no one seems to have noticed it so I'll just have to start a new topic!
We're about to start the silvertop 20v/T50 into AE85 swap...obviously the dizzy is going to be a pain...
At the moment the options are (that I'm aware of...if there's more let me know!)
1. Hole in the firewall...is it possible to get cert with a hole in your firewall!?
2. Aftermarket computer...hefty price or is there a cheapy option for this? obviously as we could't afford a real AE86 $ are a bit of an issue so yeah
3. KE7020Vwagons special brackets... viewtopic.php?t=22532&highlight=
Anyone with any experience would be much appreciated...or any advice
Cheers Will
Willdat?
Postby Dell'Orto » Thu Feb 17, 2005 12:46 am
Obviously your cheapest option is going to be the last one.
I dont rate your chances of getting a cert with a hole in your firewall, and even a Link is a few dollars more than those brackets.
Postby wde_bdy » Thu Feb 17, 2005 8:30 am
As long as you seal the hole you make, cert is no problem. But obviously talk to your certifier before you cut anything.
Callum
wde_bdy
Postby Willdat? » Thu Feb 17, 2005 9:09 am
Yeah we're just about to buy a mig welder so re-sealing the hole is a definite possibility (not just for certification reasons, but it's going to look a damn sight better!).
With cert do you start the consultation process with a certifier before you even start?
Willdat?
Postby wde_bdy » Thu Feb 17, 2005 9:59 am
Its usually best to, find a certifier who is comfortable with what you plan to do as it saves redoing stuff.
Callum
wde_bdy
Postby Willdat? » Fri Feb 18, 2005 9:19 am
Certifier said "As long as you put back in to compensate what you're taking out" basically will weld in a box on the other side...stops water getting into the interior too...
Willdat?
Postby spencer » Sun Feb 20, 2005 6:55 pm
dont cut a hole in your car it can be legal but I have been there and its ugly try a megasquirt and edis as I am now. Or one day I may get around to making some more brackets, anyway its the thermostat housing that sticks out the most
ms63 crown
spencer
Postby suberimakuri » Sun Feb 20, 2005 11:12 pm
10lb sledge.. no cutting required.
suberimakuri
Postby Willdat? » Mon Feb 21, 2005 11:05 am
ke70wagon20v wrote:try a megasquirt and edis
Pray tell what this mod is/involves :oops:
The sledge hammer is tempting...
Willdat?
Postby suberimakuri » Mon Feb 21, 2005 11:24 am
suberimakuri
Postby Willdat? » Mon Feb 21, 2005 12:28 pm
matey potatey that sounds good...whereabouts in NZ can we get access to them or do we have to shi[p them over here?[/b]
Willdat?
Postby dskd » Mon Feb 21, 2005 8:39 pm
go with the 10lb sledge.. no cutting required.
stand on the gards faceing the front of the car and got hard :lol:
IM NOT GETTING LESS HAIR IM GETTING MORE HEAD
dskd
Postby suberimakuri » Mon Feb 21, 2005 9:12 pm
not the guards bro, stand on the cowl, closer to the ankles.
suberimakuri
Postby spencer » Mon Feb 21, 2005 9:36 pm
you can bust out the 10lb for the dizzy but not the thermostat housing it sticks out like 100mm
ms63 crown
spencer
Postby suberimakuri » Mon Feb 21, 2005 10:05 pm
been there done that.
suberimakuri
