by RS13 » Thu Feb 17, 2005 1:11 pm
Heh, you need a manual to take a 4K apart?
Honestly, they are the most basic engine EVER, thats why polytech use them for students to practice on! Just make sure when you pull it apart you make timing marks etc, to know where things go back on.
If you're gonna drop the hot cam in, it'd probably be worthwhile getting a 3K head installed to bump the compression up. And, as was mentioned before, a good cheap mod is using a 1300 escort carb, with an adaptor plate to fit it to the 4K manifold. Then, you might wanna hunt around for some extractors for the 4K.. honestly, you'd be spending $200 tops for all these mods. They go pretty hard in the right car, I had a bog standard 4K in my stripped KP60, it beat my mates twincarb Prelude until about 80kmh! Awesome wee motors.
Anyway.. HTH!
