ok next 4afe question
Postby shaggz » Thu Feb 17, 2005 1:15 pm
my motors the 4afe .................. btu its single cam not dohc i cannot find any specs of the sohc motor only the dohc version, anynoe know the true power output etc of this motor, or where i could find it ive searched all over google to find it
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Postby wde_bdy » Thu Feb 17, 2005 1:20 pm
Are you sure its not twin cam?
Like the 1UZ, the 4AFE runs one pulley on the head, the second cam is driven off the first.
Callum
wde_bdy
Postby RS13 » Thu Feb 17, 2005 1:20 pm
G = Wide angle DOHC (more power)
F = Narrow angle DOHC (more economy)
4A-FE DOHC 4/22.3 95-98 1587 115@6000 109@4800 81 77 9.5:1 JP
As your other post is regarding a 1999 4AFE, I'd assume these stats are the closest? 115bhp at 6000rpm seems a tad much, but meh.
If you go to the top of the tech section, theres a thread called,
"All you ever wanted to know about Toyota Engines"
Or something like that.
RS13
um the states dont say a sohc version
Postby shaggz » Thu Feb 17, 2005 1:43 pm
yip its sohc not dohc i went into the local toyota yard , very intrestingly well more worrying actually i ant find anything on the sohc version, it goes allright its got a pod and headers done thats all i mean its not quick and doesnt pull hard really,but for a 1.6 wagon im happy my model is the 1999 corolla 1.6 xli spec,if someone could shed sum light that would be great
shaggz
on the motor the sticker
says 4-fe but on the chassie code on the fire wall it says 4afe.......
shaggz
Postby CozmoNz » Thu Feb 17, 2005 1:46 pm
they didnt make 4afe sohc did they?
can we see a pic of your engine bay... if you have one just lying around sort of thing.
i highly doubt they kept putting in sohc engines into 1999 cars!!!
Rayne For President!
CozmoNz
Postby RS13 » Thu Feb 17, 2005 1:50 pm
Are you blind? I just gave you the specs for the 4AFE, as provided by the Toyota engine page.
It is TWIN CAM!! The second cam is driven off a pully from the first, hence why it appears to be a SOHC.
And can I just say, from personal experience, Toyota themselves can be wrong sometimes, they're just people too.
RS13
Postby CozmoNz » Thu Feb 17, 2005 1:57 pm
RS13 wrote:Are you blind? I just gave you the specs for the 4AFE, as provided by the Toyota engine page.
dont tell me :P his engine.
im just saying, i dont know of any 4afe with sohc, toyota did some random things in the past....
so what does the cam cover look like? and what about the cam gear cover ^_^. this is interesting.
CozmoNz
ill try upload a pick for you all
Postby shaggz » Thu Feb 17, 2005 2:00 pm
i saw the specs bit and understand the bit bout the pulley etc ill go grab my hand book etc and have a good look in my engine bay but from wot toyota said it is sohc even tho humans make mistakes, and im still not sure either way i dont look anything like my mates gli version wagons motor yet they both 1.6 i guess he mite have the 4age,ill have a ganda
shaggz
Postby CozmoNz » Thu Feb 17, 2005 2:07 pm
Looks plenty dohc :P.
CozmoNz
Postby Adamal » Thu Feb 17, 2005 2:12 pm
If your leads go in the top, DOHC you got,
If your leads go in the side, you've got a SOHC ride.
Postby Mr Revhead » Thu Feb 17, 2005 2:24 pm
easiest way to settel this si to post up or send me your FULL model and frame number
then ill post up a screen shot of what the cams etc look like 8)
here goes
Postby shaggz » Thu Feb 17, 2005 3:24 pm
jt772aeb107062670 is frame number ae111 mdoel 4afe 1587cc is me motor 1999 toyota corollz xli station wagon 5 speed white mags lowered cd player wot else yuo need ..................heheh cheers ill await yuor answer adn my leads go in the top of motor but my plenum/intake runners look different from the above picture
shaggz
Postby Mr Revhead » Thu Feb 17, 2005 3:30 pm
here ya go
its twincam, intake is driven off the exhaust cam
fyi not ALL f heads use this set up, there is the odd one that drives both cams
revhead your a star
Postby shaggz » Thu Feb 17, 2005 4:17 pm
cheers man thanx for that topic laid to rest thanx heaps
shaggz
Postby RS13 » Thu Feb 17, 2005 9:51 pm
Ahh, sa'll good Cozmo, I was aiming at Stephen Bedford.
Besides, I knew I was right! :wink:
RS13
Postby matt dunn » Tue Feb 22, 2005 12:47 am
Adamal wrote:If your leads go in the top, DOHC you got,
This is pretty much the best way of telling that i've found too.
