Celica Oil Leak
Celica Oil Leak
Postby Caveman » Sun Feb 20, 2005 6:55 pm
Hi
I've got an oil leak in my celica. I know its coming from the rocker cover. Oil leaks out of a little hole which looks factory. Im going to take it off to have a look but I thought i'd ask first for advice. Its a 3SGE in a ST162.
AW11 Track Toy
Formerly known as 1998
Caveman
Re: Celica Oil Leak
Postby ee904age » Sun Feb 20, 2005 7:12 pm
1998 wrote:I know its coming from the rocket cover.
lol you might want to do somthing about the rockets first, they dont do any good inside an engine.
But on a serious note, where on the cam cover is it leaking? ie: where the covers meet the head, near the filler hole or what?
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Dr-X » Sun Feb 20, 2005 7:19 pm
If you suspect it's the rocker cover, just replace that gasket and see what happens. Cheap as anyways.
Dr-X
Postby peas » Sun Feb 20, 2005 7:29 pm
They leak from there all the time... I have replaced "rocker" cover gaskets on my two celicas. Just a given that its goin to leak. They arent expensive and are simple to replace, you just need to know if its a one or two piece gasket from memory.
'97 Caldina GT (ST215G)
peas
Postby Caveman » Sun Feb 20, 2005 9:13 pm
I have heard rumours that there is a flaw in the rocker cover on these models however I wasn't sure. Will ST182 covers fit? Or can I just stuff a piece bung in the hole to stop the leak? Or is that hole for breathing and if I block it there will be bad side effects.
Oh there is no leaking from the gasket, only a small amount of oil which is coming out of a small hole on the right side of the rocker cover next to the distributor. I wish I had a camera to take a photo, might try and get a hold of one.
My bad on the "rocket" typo :oops: :lol:
AW11 Track Toy
Caveman
Postby Dr-X » Sun Feb 20, 2005 9:14 pm
If it's not leaking a lot, I wouldnt even worry about it.
Dr-X
