kingcorolla wrote:Really?! no difference whatsoever?
not even on a hot day? under load? high/low rpm? at speed?
what about idling at the lights, on a hot day, with a hot motor? surely..
any other mods?
that statement was sorta controversial, iMO
Dr-X wrote:Just_Juzz wrote:An unshielded filter sucks in hot air from the engine bay, hot air holds less O2 then cold air, and the engine compinsates for this by using more fuel.
That's an...interesting theory.
pyro_sniper2002 wrote:Thats sort of rite cold air compresses better than hot thats exactly what an intercooler does for example cools air down so it compresses better
thaphatty wrote:pyro_sniper2002 wrote:Thats sort of rite cold air compresses better than hot thats exactly what an intercooler does for example cools air down so it compresses better
i think the word your after is denserhot atoms shake/move alot, cooler atoms move less and are closer together or denser if you will.
pyro_sniper2002 wrote:Dr-X wrote:Just_Juzz wrote:An unshielded filter sucks in hot air from the engine bay, hot air holds less O2 then cold air, and the engine compinsates for this by using more fuel.
CozmoNz wrote:thats why you should have your turbocahrger, sucking THROUGH another intercooler then a poddie
mm cold suction....
rofl
(assuming you mean air to air) its not possible for intercoolers to cool down lower than outside air temp so it makes most sense to me to just to have a good cold air intake
*wonders if your joking or just being you again*
