Engine from auto car into manual car
Postby jeremiahnz » Tue Feb 22, 2005 11:44 am
I am looking at getting an engine orginally from an automatic car and sticking it into my car which is a manual.
What I want to know is whether there would be any issues with this? The only things I can think of are:
1) that the ECU from the auto engine may expect to be communicating with sensors/computer from the automatic box.
2) There may be some left over wires on the loom that I don't need to use.
Can anybody confirm, deny or add to any of the above?
Thanks
jeremiahnz
Postby ee904age » Tue Feb 22, 2005 12:19 pm
What type of car/engine are you talking about? We can guve you more specific answers with this info
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby thaphatty » Tue Feb 22, 2005 12:23 pm
straight forward, to start it you'll need to bridge the inhibitor switch on the g/box, and you'll have a left over linkage from where the kickdown cable was
thaphatty
Postby thaphatty » Tue Feb 22, 2005 12:25 pm
but yeah car engine etc and can give more details
thaphatty
Postby Ae92typeX » Tue Feb 22, 2005 12:32 pm
Really do need to be more spacific with the engine type, as sometimes they can vary...however as thaphatty sez, generally you can just bridge the inhibitor switch loom and away you go.
When I converted my supra to manual from automatic I did that and then completly removed the auto's ecu, so there are a few plugs left over that you wont need to use
Ae92typeX
Postby jeremiahnz » Tue Feb 22, 2005 12:39 pm
Sorry,
4afe in the car now, want to swap to a 7afe.
jeremiahnz
Postby jeremiahnz » Tue Feb 22, 2005 12:42 pm
Oh,
And what does the inhibitor switch do?
jeremiahnz
Postby thaphatty » Tue Feb 22, 2005 12:44 pm
in a automatic car the inhibitior switch stops the car from being started in drive/reverse etc.
thaphatty
Postby Ae92typeX » Tue Feb 22, 2005 12:44 pm
its in an auto car so you cannot start the car in any gear, only park and depending on car neutral.
obviously going manual you wont have a park...or switch, so you bypass it
Ae92typeX
Postby jeremiahnz » Tue Feb 22, 2005 12:46 pm
Ok, so you simply hardwire across the switch to bridge it?
jeremiahnz
Postby Ae92typeX » Tue Feb 22, 2005 12:50 pm
yep. I found the plug in mine that went to the inhibitor, made a loop inside and plugged back in the loom...just a tidy way of bridgeing it
Ae92typeX
Postby jeremiahnz » Tue Feb 22, 2005 12:57 pm
Ok, cool makes sense.
So that is pretty much it? The inhibiter and the throttle linakage?
If I am using my manual gearbox it won't have this switch will it? So do I bridge it back to the ecu cutting off the switch that would have been on the auto box?
jeremiahnz
Postby thaphatty » Tue Feb 22, 2005 1:34 pm
To answer your question as Ae92typeX wrote:obviously going manual you wont have a park...or switch
heres what you do:
find 2 wires to inhibitor switch , strip, soilder, then crimp. or whatever fasion you use to join them. :|
easy peasy
thaphatty
Postby kingcorolla » Tue Feb 22, 2005 5:48 pm
my mate did the auto-manual swap and forgot about the nuetral start switch, wondering why it didnt wanna start.
we ended up wiring it up to the A/C button, for a little extra security.
1983 Carina AA63 4age
kingcorolla
Postby Muzzie » Wed Feb 23, 2005 6:38 pm
kingcorolla wrote:my mate did the auto-manual swap and forgot about the nuetral start switch, wondering why it didnt wanna start.
Damn, thats a good idea. Have to keep that in mind for when I do my manual conversion :D
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby Mr Revhead » Wed Feb 23, 2005 7:21 pm
in the back of the plug going into the selecter quadrant, on the front of the gear box (front of car) there is i think 6-8 wires going in to it.
find the black wire, and black with white stripe
they will be next to each other in the middle.
those are the 2 you want to bridge.
also the reverse light switch plug will be different.
Postby Caveman » Thu Feb 24, 2005 10:33 am
kingcorolla wrote:we ended up wiring it up to the A/C button, for a little extra security.
Nice 8) Will keep that in mind when I do mine.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby 4ageman » Fri Feb 25, 2005 12:06 am
i thought he said he was getting a engine out of an auto and putting it in his manual car. Toyota use seperate computers for there automactic gear boxs dont they. which would mean wat you guys just told him would of confused him even more considering his car is manual and all he is doing is swapping a engine into it.
4ageman
Postby Ae92typeX » Fri Feb 25, 2005 12:12 am
nice 'correct' reading!
Think I got myself confused when I read the questions.
engine from an auto and into a manual, assuming all engine plugs are the same is just a bolt in jobbie, none of this talk about inhibitors lol
took a while for anyone to click!
Ae92typeX
Postby thaphatty » Fri Feb 25, 2005 8:18 am
ahaha! :o shit mang, bit of a $&#$% right there :?
thaphatty
Users browsing this forum: No registered users and 44 guests
