Rattles?
Rattles?
Postby samlloyd » Sat Feb 26, 2005 11:59 am
Note: I did search. Dont really find the search function the best.
Ok, What is the common rattle found in the front of the SW20? Is that specific enough? When you go over a decent sized bump. My car got a warrant just the other day so it must not be too much of a big deal, but it is annoying.
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby Rob » Sat Feb 26, 2005 2:00 pm
This shouldn't have passed but some let it go, not even sure if an mr2 has them but check your sway bar linkages, wiggle up and down....That can do it
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby samlloyd » Sat Feb 26, 2005 9:14 pm
thanks mate, ill check tomorrow
samlloyd
Postby Dr-X » Sat Feb 26, 2005 10:51 pm
You'll need to be more specific. Where is it coming from? How loud is it? Louder from inside or outside the car?
Dr-X
Postby Ae92typeX » Sat Feb 26, 2005 11:04 pm
so its a fairly 'common' one- as in you hear it in lots of mr2's?
Like X said above, more spacific about where up the front and inside/outside.
could be anything from as simple as a jack or similar not in secure and jumping over a bump.my mate had this in coincidently mr2 once
Ae92typeX
Postby samlloyd » Sat Feb 26, 2005 11:27 pm
Ok,
I have taken all the tools out from the front. wheel is very secure.
Sounds like the noise is coming from the front right, and im not sure how loud it is from outside.
I thought it was common because KiwiMR2 had told me that some mr2s have a rattle in the front from worn out somethings.
It sounds like the jack, jumping up and down over a big bump in the front, but ive put the jack in the boot, and the noise is still there.
hmm :?
samlloyd
