HRT wrote:T25 might be a bit small though
I SL1DE wrote:HRT wrote:T25 might be a bit small though
I was talking to mike86ze and he is using a t25 and said that a t28 may be to laggy but it sounds like you are getting great response from your t3 setup. I would prefer to use a bigger turbo if i can, the more power the better! There are other things like bigger injectors that I would also have to buy if i was to go with a non-ZE engine of some type.
It seems that there isnt an easy answer to this question. I guess it'll just come down to what i can find for the right money. On that note if anyones got a AE101 4AGZE kicking around PM me as this seems the best option aside from cost.
I SL1DE wrote:
Small port with reversed intake manifold and GZE pistons
I SL1DE wrote:. Im a beginner, im not trying to piss anyone off and no im not too lazy to read up or do a search, i spend more time researching than what i do actual work on the car.
Karl_Skewes wrote:if you're racing, then off boost doesn't matter.
Karl_Skewes wrote:racing and half throttle. i would hope you're on boost in a turbo car. Maybe you're in the wrong gear
Don't even try and tell me about compression and boost.
I ran a redtop (10.3:1) turbo (t3/4 1 bar) for 6 months, something which majority on internet will say will blow up.
That motor then went back into a mates car after d1 round and he went and dynoed it at 90kW at the wheels. 95kW would have been achievable without SAFC and with filter on.
Motor obviously still alive.
Karl_Skewes wrote:join the DR-X gang.
detonation and lack of fuel will blow up motor. vvega is right.
Users browsing this forum: Bing [Bot] and 16 guests
