After Market Air Filters
Postby BZG Wagon » Mon Mar 14, 2005 3:16 am
Wanting to get a POD for the rolla (20V Black Top AE101).
Just wondering what the difference is between a
* $40 Filter from a tiny jap shop in town
* $100 K&N / Jamex / Whatever
Is there a specific size or surface area I need?
Is it a matter of getting an adapter and connecting it or do I need to do more?
I will be keeping the standard exhaust for now and I dont really have any major plans for the car. I just want it to breath a bit better and give it a bit more pull (mainly at lower rev's where it is lacking).
BZG Wagon
Postby Just_Juzz » Mon Mar 14, 2005 7:45 am
If you spend the money on a k&n, it'll last you ages, simply cause it's re-usable.
The $40 one will probably not be washable.
Yo can normally put the pod straight onto the intake pipe, with the right size hoseclip.
Have you looked at a plate filter replacement instead of a Pod?
Current Ride: 1998 Caldina GT
Me, me, me, me.....
Just_Juzz
Postby pervert » Mon Mar 14, 2005 7:53 am
I've heard that cheap pod filters (i.e. Wildcat and so forth), actually flow less than a standard air filter in most cases, they are purely for wank value...be interesting to find out.
pervert
Postby Jebus » Mon Mar 14, 2005 10:34 am
Redline, are about as good as a K&N theyre re-usable as well, $100 retail, I got mine for $65 though.
Jebus
Postby Silent Knight » Mon Mar 14, 2005 11:19 am
Silent Knight
Postby AJz » Mon Mar 14, 2005 11:20 am
my K&N flat panel works so much better than my pod did. If your using a pod you need to be able to get air to it, like stick it in a Cold air box and route air to it, or stick the pod down near the bumper. Other wise its better just taking your existing flat panel into repco or what eva, and get them to match you with a K&N or wateva, i def recommend mine, but was fukin expensive for a filter.
I had vtax :(
AJz
Postby AJz » Mon Mar 14, 2005 11:23 am
wow, thats quite interesting reading bout the results.
I had vtax :(
AJz
Postby CozmoNz » Mon Mar 14, 2005 11:23 am
Its been tested, the restriction in your intake system, if you have one, is NOT your air filter, the resistance is VERY minimal.
its your airbox seutp.
most people cheat, and scrap the box putting a poddie on. Sucking lots and lots of hot air in X_X.
just get a panel filter, mod your airbox, then run a cold air feed into the box.
Whamo, best your gonna get >.> and make sure you remove all restrictions!
Rayne For President!
CozmoNz
Postby TRDWGN » Mon Mar 14, 2005 5:53 pm
That test is probably a bit too old to treat as a guide for the filters currently available..
FWIW, my carib has a APEXi replacement element in the standard airbox, I have removed the anti-resonance box from inside the guard and IMHO you will not get any additional benefit (in fact most likely a power reduction) running a pod due to heat soak... and yes this set-up made a huge difference over the standard arrangement!
I believe in the K.I.S.S. rule (Keep it simple stupid!) best bang for buck!
TRDWGN
Postby AJz » Mon Mar 14, 2005 6:30 pm
exactly, cos in the end what you want is the most power, for the least money
I had vtax :(
AJz
Postby bad20v » Mon Mar 14, 2005 7:17 pm
AJz wrote:exactly, cos in the end what you want is the most power, for the least money
Exactly, Ive gt the Blitz 'SUS' Power filter as show at the top of the page on my 20v. Its a pity bout the filtering results but I gt it for free so Im not worried too much. Its in a custom cold airbox and work really good in any conditions, even on hot days.
Thank-You.
bad20v
Postby BZG Wagon » Sat Mar 19, 2005 11:55 am
In my Familia I had a Jamex Plate Filter and the previous owner cut a big hole in the bottom of the air filter box.
- You guys reckon a similar set-up would work?
- So I basically just replace the standard Air Filter with a K&N/Apexi and keep the Air Filter Box?
- Any ideas on prices?
BZG Wagon
Postby Mr Revhead » Sat Mar 19, 2005 12:06 pm
id go for the k&n. they are easily avail, and id be a bit sus about the apexi zero manitanece for life claim....
Postby Just_Juzz » Sat Mar 19, 2005 12:39 pm
Mine was $120+ Gst, but that was at a big discount.
K&N can range from $150 up/
Me, me, me, me.....
Just_Juzz
Postby BZG Wagon » Sat Mar 19, 2005 6:01 pm
Just_Juzz wrote:Mine was $120+ Gst, but that was at a big discount.
Shit... :(
Thats a bit more than I was expecting. Im sure I will find a cheap hook-up somewhere - I always do :D .
Keep ya all posted.
BZG Wagon
Postby aesc » Sat Mar 19, 2005 6:21 pm
sh*t... :(
Keep ya all posted.
For your blacktop a K&N panel is prob around $140 retail, a bit less if you have a hook up.
If I were you id look out for one on trademe, thats what I did, got a mint one for $25. People seem to think a panel is worthless and sell em for not much more than that :lol:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby AJz » Sat Mar 19, 2005 7:27 pm
mine was that, i dont think the filter in a celica is the same size as a Levin, could be wrong tho. Def go K&N
I had vtax :(
AJz
Postby Mr Revhead » Sat Mar 19, 2005 8:42 pm
my k&n was $125 inc gst. and not through work
$150 will be full retail
Postby AJz » Sat Mar 19, 2005 8:44 pm
yea but its worth it, the flow so much better, and they last ages.
I had vtax :(
AJz
Postby Mr Revhead » Sat Mar 19, 2005 8:51 pm
didnt mean to imply it wasnt worth it.... it is. go k&n. dont bother with anything else
