handbrake light on
handbrake light on
Postby Peradx » Thu Mar 10, 2005 6:54 pm
my hand brake light has come on after replacing springs in my ae86. do you now why and how to fix?
Peradx
Postby Lloyd » Thu Mar 10, 2005 6:57 pm
Got enough brake fluid?
Postby ee904age » Thu Mar 10, 2005 7:26 pm
Yeah, some cars use the h/b light as a low fluid warning, although Ive only seen it on 92ish on vehicles it could be possible.
Where is the lever sitting? you may have messed up the cable position causing the lever to sit higher, tripping the switch. You should be able to readjust it on the hubs, if no joy there try the nut on the lever itself.(you will need to remove the trim surround)
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby rwd_mayhem » Thu Mar 10, 2005 9:08 pm
my handbrake lights on all the time as well - i just ignore it.
current: 1975 Valiant Regel
rwd_mayhem
Postby levinwreck » Sun Mar 13, 2005 6:45 pm
mine is on all the tim etoo i was told i need rear brake cali kits
Ae92 Toyota Trueno GT-Z - STILL GOING
Ae101 Toyota Levin 20V - GONE
78 Lancer - 2BWLAGE
levinwreck
Postby fangsport » Sun Mar 13, 2005 9:21 pm
the hanbrake light sensor is mounted on the lever mechanism, so it is probably a case of adjustment at the lever end.
fangsport
Postby BZG Wagon » Mon Mar 14, 2005 3:00 am
Usually it means you're low on break fluid (if its on intermittantly). If its on continious it could be the switch on the lever.
BZG Wagon
Postby Peradx » Mon Mar 14, 2005 6:59 pm
yeah, well it was the fluid being too low :oops:
Peradx
Postby B1NZ » Tue Mar 15, 2005 5:49 pm
yep, warning light are there for a reason, as for the person who said ignore it?? Do you have a death wish or something?? :roll:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Dr-X » Tue Mar 15, 2005 5:56 pm
Hope you didnt just top it up. There's only 2 reasons your fluid would be low:
1/ Your brake pads are well worn
2/ There's a leak somewhere
Dr-X
Postby gordon77 » Tue Mar 15, 2005 10:16 pm
Dr-X wrote:Hope you didnt just top it up. There's only 2 reasons your fluid would be low:
i had the same problem in my 91 fxgt and when changing the springs (requires you to take the brake hose off the shock) i inspected for leaks etc - couldnt find anything. brake pads are only 10 months old... i just toped the fluid up and bled the brakes... i will still be monitoring it tho... brakes come in usefull sometimes 8)
What is RR?
gordon77
