> cold air intakes <
> cold air intakes <
Postby fx gt » Tue Mar 15, 2005 7:38 pm
do the boxes for a cold airintake have to be a pecific size as i want to make one for my ae92 fxgt
fx gt
Postby bad20v » Tue Mar 15, 2005 7:41 pm
Nope, jst so long as they shield most of the hot air from your engine bay away from the filter. Ive seen real small air boxes that work quite well.
Thank-You.
bad20v
Postby fx gt » Tue Mar 15, 2005 7:43 pm
cheers,but one problem would thinish plastic melt in the engnie bay near the battery?
fx gt
Postby bad20v » Tue Mar 15, 2005 7:51 pm
Dont, if u can help it use plastic. Use steel or aluminium. If your mum's gt sum old baking trays, use those. Thats how I made my airbox in my old ae101 trueno. Jst clean off the biscuit stains first. Or go down to your nearest engineering store and buy sum. Its not that expensive. Gt a 1m x 1m sheet bout 1mm thick, so that its easy to cut and bend. 2 - 3 mm if your going to weld it.
Thank-You.
bad20v
Postby fx gt » Tue Mar 15, 2005 7:58 pm
sweet thanks,ill look into the baking trays
fx gt
Postby bad20v » Tue Mar 15, 2005 8:02 pm
Its the cheapest way but they work.
Thank-You.
bad20v
Postby GT4 20 » Tue Mar 15, 2005 8:03 pm
You don't want aluminium, steel or even baking trays - what you really need is carbon fibre 8)
http://www.220gti.co.nz/cold%20air%20box%20mkIII.htm
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby fx gt » Tue Mar 15, 2005 8:06 pm
do they have to have lids or not?this one there dosnt
http://www.220gti.co.nz/cold%20air%20box%20mkI.htm
fx gt
Postby bad20v » Tue Mar 15, 2005 8:39 pm
GT4 20 wrote:You don't want aluminium, steel or even baking trays - what you really need is carbon fibre 8)
Gary
Some ppl have budgets.
Thank-You.
bad20v
Postby Caveman » Tue Mar 15, 2005 8:41 pm
I guess the molecular design of carbon fibre must improve airflow some how adding HP oh and don't forget about the extra 250g you'll save in weight.
:roll:
AW11 Track Toy
Formerly known as 1998
Caveman
Postby fx gt » Tue Mar 15, 2005 8:44 pm
yip carbon fibre wld be great,so wat do yuo think about that cold air box with no lid?
fx gt
Postby bad20v » Tue Mar 15, 2005 8:56 pm
So long as the bonnet comes down and closes off the airbox from the rest of the engine bay it shud be fine.
Thank-You.
bad20v
Postby bad20v » Tue Mar 15, 2005 8:59 pm
That Mk1 air box looks almost exactly like mine in my ae111, but wif the filter coming from the back.
Thank-You.
bad20v
Postby GT4 20 » Tue Mar 15, 2005 10:00 pm
The MKI box I designed essentially uses the bonnet as the 'lid' (as per bad20v's post) - effectively enclosing the filter and only allowing air to be drawn up from under the car.
Gary
GT4 20
Postby GT4 20 » Tue Mar 15, 2005 10:02 pm
1998 wrote:I guess the molecular design of carbon fibre must improve airflow some how adding HP oh and don't forget about the extra 250g you'll save in weight.
:roll:
Oooooooh - looking a bit envious there 1998 :wink:
Now't to do with weight saving in this case (nor molecular design) - just that it was much easier to make the box out of carbon fibre as it says on the guide. And it wasn't expensive either.
Gary
GT4 20
Postby Caveman » Tue Mar 15, 2005 10:40 pm
Haha your probably right. Im still in denial. :lol:
Im happy with my aluminum flexy tubing.
AW11 Track Toy
Caveman
Postby Stu- » Tue Mar 15, 2005 10:51 pm
Thin wall alloy is fine. 0.9 or 1.2 would be best. Easy to fold and easy to weld. We've just got a 2400mm box and pan folder at work so I've been playing by making cold air boxes for the work vehicles - hilux ute, diesel econovan and the 5k liteace which I'll get to when I have time. Doesn't really do diddly for their performance but raises the bling ratio somewhat.
Project Thread
Stu-
Postby Dr-X » Tue Mar 15, 2005 10:55 pm
You could fibreglass up something nice, it would be pretty easy, too.
Dr-X
Postby fx gt » Wed Mar 16, 2005 8:21 pm
i decided ill have a box with no lid,and make it outa metals
fx gt
Postby bad20v » Wed Mar 16, 2005 11:38 pm
Sweet. Bad20v wins again.
Thank-You.
bad20v
