Not toyota but still a problem...Reverse is $&#$%
Postby jury_nz » Wed Mar 16, 2005 11:32 pm
Hey....
Well i know this ain't a toyota problem but ahh well...
My runabout is a mitsi lancer and the other day when i got in it and backed down the driveway it started shaking quite hard, I worked out it only does it when the clutch isn't fully in or out, but yea I'm kinda lost as to what it could be....
Tutors at tech said that one of the mounts might be rooted but i checked them all out and theyre fine, so short of dropping the gearbox is theer anything else i could check out before?
Bluetop Bits 4sale
viewtopic.php?t=27554
jury_nz
Postby matt dunn » Thu Mar 17, 2005 1:00 am
sounds like clutch shudder,
caused by the springs in the centre of the clutch plate,
need a new clutch plate.
Postby edwagon » Thu Mar 17, 2005 5:30 pm
Yep or a pressure plate problem, but definantly a clutch issue. What model lancer is is? The boxes just about fall out of those and the clutch kits are usually pretty cheap too. Cos its a shudder problem, definantly get the flywheel machined at the same time, can get this done easy as (and free) at a place on the shore....
edwagon
Postby jury_nz » Thu Mar 17, 2005 6:45 pm
cheers guys, yea changed the clutch plate not long ago but left the pressure plate so maybe that could be the problem, looks like the gearbox will be coming out tomorrow then, cheers for the input
Bluetop Bits 4sale
jury_nz
