engine problems with ae82
Postby dlopez86 » Thu Mar 17, 2005 9:15 pm
i have an 85 fx gt i got it off sum1 who changed the engine and ever since he changed it the car will sometimes not get enough revs when i start it and it will cut out when i rev it up, just wondering if anyone has had this problem or knows what could be the problem.. the previous owner said he got the plugs,leads,dizy cap,coil,coil modulator, computer, cam belt, and throttle sensor replaced, cause toyota motors said that was the problem but it was not.
dlopez86
Postby MetalupYoAss » Thu Mar 17, 2005 9:20 pm
check fuel pressure and flow...
MetalupYoAss
Postby THA SHZ » Fri Mar 18, 2005 11:11 am
did u check the coil and ignitor pack on it ? sumtimes the coil can be gud but the ignitor isnt or vice versa . this happened in mine . 8)
THA SHZ
Postby dlopez86 » Fri Mar 18, 2005 11:30 am
the coil was changed recently, any ideas how much ignitor packs cost?
this problem has been goin for more than a year
dlopez86
Postby THA SHZ » Fri Mar 18, 2005 3:34 pm
check tha coil with a multimeter to make sure its rite plus check the ignitor pack with a multimeter aswell and if u do have to replace the ignitor pack well pray u dont it aint cheap :D
THA SHZ
Postby ChaosAD » Fri Mar 18, 2005 5:31 pm
If it is the ignitor I have a sec hand one.
Is ign timing right? Plugs?
Is this fault intermittant?
ChaosAD
Postby dlopez86 » Fri Mar 18, 2005 7:50 pm
not to sure wat intermittant means, but sometimes it will start fine and other times i have to restart it several times until it starts properly. i need to find some1 with a multimeter cause i dont have 1
dlopez86
Postby ee904age » Fri Mar 18, 2005 10:13 pm
dlopez86 wrote:not to sure wat intermittant means, but sometimes it will start fine and other times i have to restart it several times
You just explained what it means.
You will only need an el cheapo multimeter, you should be able to pick one up from supercheap or dick smith for around $15. It will also come in very handy in the future.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby dlopez86 » Fri Mar 18, 2005 10:49 pm
ok im gonna go pick one up tomorow. hopefully its not the ignitor cause im quite broke
dlopez86
Postby dlopez86 » Mon Mar 21, 2005 3:08 pm
well now i have anutha problem my clutch went out and i dont have $600 to take it to a mechanic
dlopez86
Postby THA SHZ » Mon Mar 21, 2005 3:59 pm
dlopez86 wrote:well now i have anutha problem my clutch went out and i dont have $600 to take it to a mechanic
Maybe its about time to sell the car then .
THA SHZ
Postby dlopez86 » Mon Mar 21, 2005 4:37 pm
thats what i was thinking but dont kno how much to sell it for
dlopez86
Postby THA SHZ » Mon Mar 21, 2005 5:09 pm
u should be able to get a g for it but thts about it but once agan depends on wot the customer is willin to pay :?
THA SHZ
