sizing.
sizing.
Postby z|gen » Wed Mar 16, 2005 8:50 am
yo
is there much of a difference in dimensions between the 1jzgte and the 1ggte ?
in terms of length of block, head, and width and height etc ?
AE91 SUPERCHARGED COROLLA
z|gen
Postby z|gen » Wed Mar 16, 2005 8:04 pm
anyone ?
z|gen
Postby Ae92typeX » Wed Mar 16, 2005 10:00 pm
both fit pretty snug into a ma/ga70 supra, so they cant be too different.
If noone here knows for sure ask on the supra forum as a few of the guys there have done conversions with these engines I think.
Ae92typeX
Postby z|gen » Sat Mar 19, 2005 4:38 pm
bump - have searched the mk3 supra forums nz, but that didnt bring back anything, anyone else got some ideas or links ?
z|gen
Postby Si » Sun Mar 20, 2005 1:32 am
Heres the 1jz info, dimensions included.
Displacement : 2491cc
Type : Twin Turbo Inline 6 Cyl
Valvetrain : Belt driven DOHC, 4 valves per cylinder
Fuel System : TCCS EFI, Premium Unleaded
Ignition System : Direct fire ignition
Combustion Chambers : Pent Roof
Compression Ratio : 8.5:1
Bore x Stroke : 86 x 71.5
Peak Power : 280PS [206 kW] @ 6200rpm
Peak Torque : 37.0 kgm [268 ft-lbs, 363 Nm] @ 4800rpm
Fuel Consumption : 210 g / PS*h @ 2000 rpm
Dimensions [LxWxH] :
860 x 670 x 665 mm [Manual Transmission]
845 x 670 x 665 mm [Automatic Transmission]
Weight [complete] : 217kg [480 lbs.]
Turbos : CT12A [2x]
Compressor wheel : 37/54mm
Turbine wheel : 52/42mm
Boost : 0.60-0.69kg/cm2 [8.5 - 9.8psi]
Fuel Injectors : 380cc/min High Impedance
Intake cam timing [o-c] : 3° BTDC - 41° ABDC
Exhaust cam timing [o-c] : 46° BBDC - 2° ATDC
Camshaft duration : 224 [in] 228 [ex]
Valve clearance cold : 0.15-0.25mm [in] 0.25-0.35mm [ex]
Recommended Spark plug : ND PK20TR11 / NGK BRK6EKPB11
Plug gap : 1.1mm [limit 1.3mm]
Base Ignition timing : 8-12 BTDC [jumper TE1,E1]
Idle rpm : 600-700
Recommended Engine Oil : SAE 10W30, API SH
I am unsure of the 1gg info, but i hope this helps
si
Current: , '96 SubaruImpreza
Si
Postby z|gen » Sun Mar 20, 2005 9:31 am
sweet cheers man,
looks like il be wanting to find an auto one, as they are a bit shorter.
z|gen
Postby deaf_rattle » Sun Mar 20, 2005 10:10 am
plus the auto one will be a hell of alot easier to find and will be significantly cheaper.
what car is this going into?
I would go 1jz over the 1ggte since you will be getting custom mounts done( i presume)
Otherwise if the 1ggte bolts straight on, it would be hard to go passed the under rated potential that has to offer.
Postby z|gen » Sun Mar 20, 2005 10:26 am
yep custom mounts on a semi custom chassis, just gotta make sure the engine will fit inside the shell of the car,
im estimating around $1500 - $2000 for a complete engine ?
z|gen
Postby deaf_rattle » Sun Mar 20, 2005 11:43 am
well yeah you should be able to pick up a complete 1jz for $1-1.5k
might need to pay for the auto ontop of that.
allow abit for doing the main seals, cam seals etc timing belt etc.
what i did when i put the low milage 7mgte into my car was
head set (didnt rebuild the head, but used most gaskets and seals)
conversion set (used main seals and gaskets)
oil and oil filter
air filter
arp head studs (not necessary in your case, but an option you might take)
thermostat
new hoses, coolant and oil
new vacuum lines
it all adds up, but do it once and do it right.
So allow abit of money ontop of the engine cost.
Im sure you know already, but just a friendly reminder.
good luck wiht the project, and remember pics or it didnt happen
Postby z|gen » Sun Mar 20, 2005 11:49 am
yep, plan to give it a real good freshen up, im not sure what g/box il be using yet,
are there any major things to look out for ?
z|gen
Postby Mr Revhead » Sun Mar 20, 2005 1:05 pm
i suspect the difference between manual and auto will be the water pump or a different water pipe arrangement on the rear of the head....
keep that in mind if you fins a good manual one :wink:
Postby Si » Sun Mar 20, 2005 4:33 pm
Si
