check engine lights sw20 mr2
Postby wide2 » Mon Mar 21, 2005 6:13 pm
ok they all come on but nothing is wrong with the car like its normal temp and every thing like that it starts fine doesnt run funny it has oil ? what could it be ??
i did a seach nothing came up
wider please
wide2
Postby Al » Mon Mar 21, 2005 6:38 pm
What do you mean they all came on? Theres only one yellow/amber check engine light.
Al
Postby anthonym » Mon Mar 21, 2005 7:28 pm
Multiple warning lights generally indicate a broken alternator belt. That would be the first thing to check.
anthonym
Postby wide2 » Mon Mar 21, 2005 7:54 pm
well the belt is still there the egine fan light comes on the battery light comes on and the check engine light comes on
wider please
wide2
Postby anthonym » Mon Mar 21, 2005 8:03 pm
wide2 wrote:well the belt is still there the egine fan light comes on the battery light comes on and the check engine light comes on
Then it's probably the alternator itself, check that the battery is charging when the engine is running.
anthonym
Postby wide2 » Mon Mar 21, 2005 8:35 pm
well i drove it home from work last nite which is about 40 kms i think the battery would be flat by then woundt it and its starting fine
wider please
wide2
Postby Alex B » Mon Mar 21, 2005 10:19 pm
why does the exaust light come on when there is no alternator belt??? i get the charge light but uhh this dont seam to make sence to me
Postby matt dunn » Mon Mar 28, 2005 10:57 pm
pyro_sniper2002 wrote:why does the exaust light come on when there is no alternator belt??? i get the charge light but uhh this dont seam to make sence to me
The dash uses the alternator as bulb check function so all those lights will come on when the alt light comes on.
They will all come on when the car is not running with the ign switched on.
That is normal. Amazing how many people don't know that.
Matt
Postby ps165 » Mon Mar 28, 2005 11:07 pm
have you done a dianostic test. bridge E1 and TE1 in the dianostic box (sorry dont know where it would be in a mr2)
ps165
Postby Adamal » Mon Mar 28, 2005 11:23 pm
ps165 wrote:have you done a dianostic test. bridge E1 and TE1 in the dianostic box (sorry dont know where it would be in a mr2)
Towards the drivers side of the engine bay, at the rear. It's clearly labeled and in a bit of an open space, its hard to miss.
