MR2 turbo pistons. Pump gas. Piddly td04 @ 10psi = 160rwkw.
Luke - BZG wrote:MR2 turbo pistons. Pump gas. Piddly td04 @ 10psi = 160rwkw.
http://english.auto.vl.ru/catalog/583/
It's saying on here that it should almost put that much power out as stock? But maybe thats the same case as the Levin supposedly putting out 165hp stock.
TRDmod wrote:the 2 litre 4cyl beams engine has huge poteltial, i mean N A alone it has good kw ratings, you can always get a hks or reddy turbo kit made for altezzas....not expensive, low psi and get yourself 210 kw easy
4age_aw11_ae86 wrote:Yeah that car did the targa. Nice job indeed
nemesis wrote:Sorry but that's utter BS, these kits may be relatively inexpensive (depending on your definition) but they are bodge. It costs a lot of money to effectively and reliably turbocharge the Altezza 3SGE. Turbotezza has spent a fortune making his reliable after it blew up using one of these kits, and he's still making less power than the Toyota NZ Altezza touring cars were making NA
turbo tezza wrote:This is coz my car is in very mild tune. If i wanted to run more boost i could, with more advance, it would be over 200 rwkw,
thing is i don't need any more power. Its fine just the way it is.
And yes the engine has alot of potential.
You would be struggling to do a 2JZGTE coversion for near $10K. Engine to start with are about $4k.
UZ would be the way to go.....
Mr Revhead wrote:all depends on ya budget!!
throw me enough cash and im sure i could arrange a 2uz-ftte![]()
but yes the TRD catalouge does ahve a few tasty bits for them!
dunno bout the chip though.....
beeker wrote:With trying to piss anybody off, it is impossible to beat OEM engineering for value for money and reliability. It might look like it at the beginning, but over time you just cant do it. These OEM's spend hundreds of millions on R&D, and you just cant replicate that in your back shed or small tuning house. I would personally either do a mild tune or if reengine with a proven engineered end to end solution.
Users browsing this forum: Google [Bot] and 27 guests
