4age/4agze heads similar
Postby crispy'86 » Wed Mar 23, 2005 11:59 pm
Going to do a head gasket for a guy i know, he wants to put a 4age big port blue top head onto his 4agze. It's a big port 4agze from an ae92 so are there differences between the two with oil galleries and water galleries in different place?? Any advantage/disadvantage with this? he was going to put blue top cams in but he thinks a 4age head would do the trick. I'm not so convinced it'll be a straight forward thing.
Any people know??
Engine running a turbo set-up
crispy'86
Postby ATAl » Thu Mar 24, 2005 12:04 am
They are exactly the same head, and to remove the head you have to take the cams out anyway so it would be far easier just to swap cams.
ATAl
Postby Drifter4ag » Thu Mar 24, 2005 12:06 am
swap swap mate
no diff
headgasket use BR900 from appco/repco
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
4age
Postby crispy'86 » Thu Mar 24, 2005 8:49 am
yeah i know about taking the cams out to take head off, i've done enough of them but haven't come across the head swapping before
crispy'86
Postby Bazda » Thu Mar 24, 2005 2:36 pm
use the bluptop cams, they have better duration, makes the gze rev out a bit better.
Postby FLAWLES » Thu Mar 24, 2005 4:10 pm
hey bazda do u have blue top cams in ur ze?
did u have any probs starting the car afterwards?
reason being i slapped some blue top cams in and " timed them " but no go. i have spark, fuel , air , dignostics are sweet
any ideas?
oh and just go get a TRD head gasket man there cheep anuff dont piss around with after market stuff
ether TRD or OE
nuff said
FLAWLES
Postby vvega » Thu Mar 24, 2005 4:43 pm
hahhahahahhahahah
:D
v
vvega
Postby FLAWLES » Thu Mar 24, 2005 5:43 pm
vvega wrote:hahhahahahhahahah
:D
v
i forget how much i hate you :lol:
im towing my car to you so u can fix it
its payment for pushing your car around all bloody day :lol:
FLAWLES
Postby ChaosAD » Thu Mar 24, 2005 7:15 pm
Have you set the tappets?
ChaosAD
Postby Bazda » Thu Mar 24, 2005 7:49 pm
yep i just slapped them in, it was all sweet, the tappets were fine, clearances were all within tolerance.
maybe u left off some wire...
4agzet
Postby crispy'86 » Fri Mar 25, 2005 10:26 pm
ether TRD or OE
nuff said[/quote]
with the trd gasket wouldn't it raise the compression a bit much for detonation to take place?? ummm i forgot to mention this guy is running a turbo setup on it too
crispy'86
Postby Mr Revhead » Sat Mar 26, 2005 10:56 am
seeing as its a big port ze its the lower comp engine, so fitting a 0.8MM trd will probably be fine, depends on the boost and if anything else has been done to alter the compression. it certainly wont raise the compression to the same levels as the small port ze!
the stock gasket is 1.2mm
4agze head
Postby crispy'86 » Sat Mar 26, 2005 7:25 pm
Yep i'll let him know
thanks people :)
crispy'86
