C52 gearbox oil volume??
Postby demis » Mon Mar 21, 2005 8:23 pm
Hi how much oil dose a c52 gearbox need on a ae92 levin (small port if it makes any diffrance)
i want to buy some tomorrow from ripco, i would ask them but thay are $&#$% muppets
thanks
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby Mr Revhead » Mon Mar 21, 2005 8:58 pm
a 4 ltr pack will do it.
they hold around 3.5 litres. just fill it till it reaches the fill bung.
Postby demis » Mon Mar 21, 2005 9:08 pm
hi
i was wanting to know the amount as i already have 1 litre of it so just want to buy what i need to fill it up from dry
i seem to rember it was arout 3.2 or 3.6 litres
thanks
demis
Postby Mr Revhead » Mon Mar 21, 2005 9:29 pm
its under 4 ltrs and over 3.3
hows that?
Postby AceSniper » Mon Mar 21, 2005 10:13 pm
I thought it was right on 2.6lt
so it works out best to just buy a 4lt
AceSniper
Postby Mr Revhead » Mon Mar 21, 2005 10:22 pm
last one i did a coupla week ago took most of a new 4ltr pack
Postby demis » Tue Mar 22, 2005 7:27 pm
ripco's dodge book said 2.4-2.6 liters
i seem to rember that last time i changed it i bought 3 1 liter bottles
so i bought 2L more to go with the 900ml i already have, if thats not enough then i will have to go buy some more
thanks for the help peoples
will let you know how i get on
demis
Postby Mr Revhead » Tue Mar 22, 2005 8:00 pm
*wonders wtf box he fitted the other week*
Postby CozmoNz » Tue Mar 22, 2005 8:58 pm
if its anything like the 20v 4age gearboxes, its 2.6ish litres.
Rayne For President!
CozmoNz
Postby demis » Fri Mar 25, 2005 9:29 pm
I filled it up today
it needed 2.6 liters :D
demis
Postby Stu- » Fri Mar 25, 2005 9:36 pm
I've read in several places that the starlet c52 gearbos is supposed to take 2.2 litres. But when I filled mine after the rebuild etc it took 3.3 ish to bring the level up to the filler hole.
Project Thread
Stu-
Postby Mr Revhead » Sat Mar 26, 2005 10:45 am
yeah thats what i found.....
so best way is just fill it to the bung hole 8)
Postby AceSniper » Sat Mar 26, 2005 5:29 pm
could be that some oil dosnt drain when you remove it meaning it takes 2.6lt to fill, but when its been removed an drained it needs more since the box was on a angle and more oil came out? dono I rember repco's book saying 2.6
AceSniper
Postby Stu- » Sat Mar 26, 2005 8:57 pm
I had my gearbox in pieces while putting in the lsd so it definitly was dry inside. Valid point thou for people just doing a fluid change. Usually I go for a bit of a rape around the block to get the fluid hot before I drain it, means you get most of it out.
Project Thread
Stu-
