clutch not disengaging?
Postby scope » Mon Mar 28, 2005 8:04 pm
hey
after giving my ke30 a bit of a thrashing my clutch decided it doesn't want to work. it seems that it won't go into gear like the clutch isn't disengaging. the cable ain't broken, i've checked that. if i start the car in gear, it doesn't stall which makes me think that it's not disengaging.
any one know how to fix this?
thanks
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby dotdog » Mon Mar 28, 2005 8:10 pm
I had this happen to a fwd starlet once, the hole clutch assembly had sezied up and didnt disengage, i think we had to pull the gearbox off to clean it all up
dotdog
Re: clutch not disengaging?
Postby Dr-X » Mon Mar 28, 2005 8:17 pm
scope wrote:if i start the car in gear, it doesn't stall which makes me think that it's not disengaging.
I dont quite understand what you're saying here. Are you able to get into gear with the car off?
Dr-X
Postby scope » Mon Mar 28, 2005 8:18 pm
don't normally if you put the car into a gear and start, it will jump forward and stall? it is not doing this
scope
Postby Dr-X » Mon Mar 28, 2005 8:24 pm
So, if you're sitting at idle, you cant get into gear at all? This obviously sounds like a clutch problem. But the fact that it wont even go into gear while the car is off is very odd.
Dr-X
Postby scope » Mon Mar 28, 2005 8:26 pm
yeah that's why i think the clutch is stuck being engaged. if i'm on very flat ground, and put into first and try move, it will move at like 1cm/second
scope
Postby Dr-X » Mon Mar 28, 2005 8:29 pm
Hang on, how do you put it into first? Are you sure you've described these smyptoms correctly, because it sounds very odd. Either way, the gbox needs to come off, so you may aswell whip it off and see what's wrong.
Dr-X
Postby scope » Mon Mar 28, 2005 8:31 pm
clutch in, put into first, try take off normal, give it alot of revs, moves very very slowly. could it be just major major clutch slippage but instead of slipping, it's stuck? :D
scope
Postby Dr-X » Mon Mar 28, 2005 8:33 pm
You said before that you couldnt get into gear, and now you're saying you can get into gear. Please clearly describe your symptoms. From what you just said, your clutch is rooted and slipping really badly. It's certainly NOT stuck on.
Dr-X
Postby scope » Mon Mar 28, 2005 8:37 pm
ahh yes. bit of a mistake i wrote. by 'not into gear' i meant it won't move properly :p slap slap
should i just get under the car and have a look? never run into this sort of problem so not really sure how to fix (or describe it properly!)
scope
Postby Dr-X » Mon Mar 28, 2005 8:50 pm
Definately sounds like a buggered clutch.
Dr-X
Postby Chickenman » Mon Mar 28, 2005 8:55 pm
DR-X you pig F***er its obviously the...
SUNVISOR :lol:
Baby Jesus
Chickenman
I Am The Walrus!
Postby Dr-X » Mon Mar 28, 2005 9:05 pm
Welcome back :wink: :lol:
Dr-X
Postby YeMs » Mon Mar 28, 2005 10:01 pm
well u cant drive it like it is ;) so i would sugest pulling the gearbox off and inspecting the clutch setup. takes about 15-30 mins to pull of the gearbox off. u will probly find the thrust bearing has siezed on the shaft or sumthing. does the clutch feel normal wen u depress the pedal?
Your local Hybrid Elite tech
YeMs
Postby scope » Tue Mar 29, 2005 2:52 am
nah it seems more stiff to push in
scope
Postby Leon » Tue Mar 29, 2005 10:30 am
start pulling stuff apart.
Postby RS13 » Tue Mar 29, 2005 1:22 pm
Sounds like you've murdered your clutch plate. Sometimes with cheaper clutches, if you keep dumping the clutch/sidestepping etc, the clutch plate can often break apart, so the centre sprung part snaps off the actual friction surface. It means that when you put the clutch in, you may get horrible scraping noises, and it won't go into gear.
RS13
