40mm crank strength
40mm crank strength
Postby toy scort 1day » Mon Mar 28, 2005 2:14 am
anyone out there able to tell me how much weaker the ae82 40mm
crankshaft is. have on and am keen for low boost turbo setup :?:
p.s this is probably the most informative site iv found to date
toy scort 1day
Postby Mr Revhead » Mon Mar 28, 2005 10:57 am
dont know any specific figures.. but they arnt weak.
a low boost setup will no tbe a problem. pistons will be a prob before crank
Postby Rick » Mon Mar 28, 2005 11:01 am
I cant say how much weaker the crankshaft is, but that is not the only difference to the latter models, your motor also has a weaker 3 rib block as aposed to 7 ribs in later versions, weakers conrods, gudgeon pin dia is 2mm smaller and the big end bearing dia is also smaller. I think the first generation 4AGE's were good for about 150hp, I would personally go for the 4AGZE or the Hi compression smallport red top motor.
take a look at this site for more info
http://www.club4ag.com/
Postby Mr Revhead » Mon Mar 28, 2005 11:09 am
what he has will be fine for low boost (i assume under 10psi?)
have you ever heard of a 4age block giving probs?
the trick is the tuning.
if i was gunna make a cheap low boost 4age id use a bluetop. easier and cheaper to find than the small port. and 4agze prices are insane. not worth the $$$
Postby suberimakuri » Mon Mar 28, 2005 5:31 pm
on 200,000kms motors running 1 bar on a t3/4...... the first things to give way are the piston skirts. This is with reasonable tunes (lots of fuel, low advance), but with plenty of track time.
crank + rods = no problem in our testing.
10lbs on T25 should run for ages if tuned right and block is reasonable to start with.
suberimakuri
Postby RedMist » Mon Mar 28, 2005 6:07 pm
3 rib block isn't weak. I run a highly developed 4age race 3 rib with little issues. The atlantics also used to use the 3 rib as it was lighter.
But I would have to concur with the pick of a 7 rib smallport as a great start for development.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby pc » Tue Mar 29, 2005 10:52 am
I believed the using the stronger 7 rib block was a good idea until I looked at it with the head off it. the water jacket goes between the piston walls and the outside of the block, so I don't see how the extra stength is worth the extra weight.
There doesn't look like there would be much force on the block in that area.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby suberimakuri » Tue Mar 29, 2005 10:55 am
non tvis 7 ribs have the squirters in them.... this is the only advantage to this block imo... bigger oil pump can be put in bluetop block.... yada yada.
suberimakuri
