ae101 corolla 4age to 4agze
Postby shing » Mon Mar 28, 2005 2:07 pm
my mate has recently brought an ae101 corolla with 4age, he is wanting to drop that engine out and put in a 4agze, what needs to be swapped? im guessing, engine wiring and computer, or is there more to it? and also how much do you rekon he will be looking at for it, we will be doing the work our self so pretty much just price of engine, box and loom to computer.
shing
Postby ee904age » Mon Mar 28, 2005 2:16 pm
Do a search, this is probably the 2nd most asked Q on Toyspeed.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby shing » Mon Mar 28, 2005 2:47 pm
done a search couldnt find anything maybe im using the wrong keywords :?
shing
Postby dragg_racer666 » Wed Mar 30, 2005 8:20 pm
you just really want bigger injectors, and a stronger gear box, clutch and pressure plate. its pretty strait forward
dragg_racer666
Postby Mr Revhead » Wed Mar 30, 2005 8:58 pm
it would be cheaper to convert the 20v to turbo.
Postby Rob_GTZ » Thu Mar 31, 2005 6:04 pm
dragg_racer666 wrote:you just really want bigger injectors, and a stronger gear box, clutch and pressure plate. its pretty strait forward
Why would he need Bigger Injectors, stronger gear box?
He has said that they are strait swapping the 4AGE for 4AGZE, therfore the 4AGZE injectors & G/Box are going to be used
Rob_GTZ
Postby FLAWLES » Thu Mar 31, 2005 6:13 pm
the ze runs bigger injectors and a stornger g-box
it wouls be a straight swap in motors and ecu and box
but like mr rev-head said just turbo the 20v
FLAWLES
Postby Mr Revhead » Thu Mar 31, 2005 6:15 pm
not quite a straight fit with the ecu.. some of it is integrated in the loom, and the looms are different... its not as easy as say fitting a 4age to a 4afe car
Postby FLAWLES » Thu Mar 31, 2005 6:16 pm
Mr Revhead wrote:not quite a straight fit with the ecu.. some of it is integrated in the loom, and the looms are different... its not as easy as say fitting a 4age to a 4afe car
sorry, yea the loom would be diff, diff ecu plugs arint they?
FLAWLES
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
