Flywheel on a 4age...
Postby LEVIN GTV » Thu Apr 07, 2005 5:13 am
Hey guys,
Thinking about getting a flywheel on my 4age.
Basically what should i look for?
What brands?
How exactly will a lightened flywheel effect the performance of my car?
What set ups do people currently have on their cars?
Any help will be awsome
Cheers All
LEVIN GTV
Postby pc » Thu Apr 07, 2005 9:49 am
I don't have much experience with lightened flywheels but I had some of the un-necessary weight removed from te outside of mine and the engine revs a lot more freely.
If you are wanting a really light flywheel I would suggest getting a specifically made light flywheel and not lightening a factory one. Not worth the risk of it exploding.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Dr-X » Thu Apr 07, 2005 9:50 am
Less rotating mass, less intertia in the driveline. It will rev more freely, but you'll find it harder to get off the mark. This has been debated several times, you'll find a few threads using the search function.
Dr-X
Postby Distrb » Thu Apr 07, 2005 9:59 am
Distrb
Regular Poster
Postby Dr-X » Thu Apr 07, 2005 10:03 am
Dont forget this one
http://forums.toyspeed.org.nz/viewtopic.php?t=29295
Do it right, or dont do it.
Distrb wrote:indeed there are many
viewtopic.php?t=24579&highlight=light+flywheel
And this is the one where some jackass tried to tell me I was confused, because according to him, auto's do have flywheels, right behind the flex plate :roll:
Dr-X
Postby Distrb » Thu Apr 07, 2005 10:23 am
i just picked some from the massive list of already been topics that came back
Dr-X wrote:Dont forget this one
indeed, that is nuts.. i remember a chap at meremere who owned a green rx-3? that had his let go in a similar fashion.... just about killed someone if i remember correctly
Distrb
Regular Poster
Postby spencer » Thu Apr 07, 2005 10:28 am
I have one on an 85 with 20v its an ae86 billet one from japan wieghs 3.8kgs cost me $6-700 posted from a mate in jap. can also get a 20v one if you want a slightly bigger clutch wieghs 4.3? pm me if you get keen and i can get hold of my mate see if hes got any
ms63 crown
spencer
Postby Mr Revhead » Thu Apr 07, 2005 3:00 pm
depending on ya clutch set up you could fit a blacktop one, they are the lightest of the stock ones.
if yougo too light itll be a pig on the road. cars have flywheels for a reason!
make sure you read those above threads properly, the first pages of some can be misleading....
Postby vvega » Thu Apr 07, 2005 8:19 pm
Distrb wrote:i just picked some from the massive list of already been topics that came back
unfortunatly it has nothing to do with lightened flywheels.... and was locked accordingly
v
vvega
Postby Dr-X » Thu Apr 07, 2005 9:00 pm
No, it was locked because you spammed it with your know-it-all-ism.
Dr-X
Postby Mr Revhead » Thu Apr 07, 2005 9:07 pm
spammed? or corrected? theres a difference :wink:
Postby vvega » Thu Apr 07, 2005 9:10 pm
Dr-X wrote:No, it was locked because you spammed it with your know-it-all-ism.
that threed was a load of crap full of missinformation like most of the things you have been posting
im sorry you can't see that but its good to see the powers that be can.......
and thats all that really matters
give up and get over it
i have :D
v
vvega
Postby [V8ROLA] » Thu Apr 07, 2005 9:30 pm
well considering if that flywheel was stock in that mustang then there is no way it would handle 7800RPM !!!!! so that would explain the way it destroyed itself.
if you going that high in revs on a V* you need to go either billit or atleast custom no way a stock one will spin like that under that abuse!!!!!
and a lightened rotor flywheel will still weigh more than a V8 one LMAO there huge!!!!!
1995 ducati 900ss with a 2001 fuel injected motor, ramflow intake, open pipes, polished wheels and afew other mods.
more to come ;)
1983 RX7 series 2 with small block chevy.
http://photos.data.net.nz/?dir=V6ROLA%2 ... sion%20%2F
[V8ROLA]
Real Life Mechanic
