belt problems, help
dragg_racer666
- Toyspeed Member
belt problems, help
ok i got up this morning and started my car. it was warming upand i came back inside. but when i went back out to leave i looked at the front of my car and i seen that the s/c , water punp belt had fulen off and also was the altinator p/s belt had fullen off and were just lying on the ground. now what could of corsed these belts to fall off there pullys. they were on there properly. and also the altinator belt was all frayed on tha r/h side. what has happened to my engine
yea check all your pulleys as they my not be spining around and causing the belts to stretch and rip off. also check to see if your water pump is spinning aswell, as it could rust and stop spinning.
hope that helps.
hope that helps.
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
1994 Mazda Lantis
EX:
dragg_racer666
- Toyspeed Member
dragg_racer666 wrote:all my pullys are spinning fine. maby the belts are just $&#$%. i'm thinking it may be the altinator, i'm going to put a new one on today and i'll see how it gose. i'll post back after that
how much boost you running? what size is your crank?
CURRENT:
1994 Mazda Lantis
EX:
1994 Mazda Lantis
EX:
dragg_racer666
- Toyspeed Member
dragg_racer666
- Toyspeed Member
dragg_racer666 wrote:dude no need to attack me on my spelling. i dont care if i can or not.
yea i'm going to get new belts tomorrow. and if i have any more trouble i'm just going to put in it the guarage for them to play with. i think the supercharge / waterpump belt was streched and worn.
as other have said could be worn belts as in chunks taken out of the "V" groves, but you havnt told us if there is or not.
let us know what happend when you get new belts
clint
CURRENT:
1994 Mazda Lantis
EX:
1994 Mazda Lantis
EX:
