Altezza pistons into Redtop 3sge?
Postby RomanV » Thu Apr 07, 2005 4:06 pm
Hi there.
I was wondering if these:
http://www.trademe.co.nz/Trade-Me-Motor ... 117705.htm
Pistons would be compatible with a red top 3sge engine.
Although Altezza pistons run a higher compression, correct?
altezza 3sge pistons
Postby Celica RA45 » Thu Apr 07, 2005 7:40 pm
yes they will fit only .5 higher in comp thou
Celica RA45
Postby Adamal » Thu Apr 07, 2005 7:49 pm
Are those the diameter for the original bore size? Gotta be careful with that. If you're going to put new pistons in, the chambers might need to be bored out even further and you might find those ones have way too much clearance between the piston and the wall...
