Exhaust strangling 4k
Postby 1goodidea » Fri Apr 08, 2005 5:33 pm
If you run a 4k on the standard exhuast on a kp60 starlet that originally had a 2k would it affect how it runs? ie not idle very well?
1goodidea
Postby pervert » Fri Apr 08, 2005 5:38 pm
It shouldn't do, I would imagine the exhaust diameter would be the same, but I could well be wrong... :?
pervert
Postby 1goodidea » Fri Apr 08, 2005 5:42 pm
pervert wrote:It shouldn't do, I would imagine the exhaust diameter would be the same, but I could well be wrong... :?
yeh well thats what i thought!
but i'm trying to get to the bottom of my idle problem its very ruff, as if the motor has lumpy cams but i no that it doesn't
1goodidea
Postby pervert » Fri Apr 08, 2005 5:45 pm
Is it running on all 4 cylinders?
pervert
Postby 1goodidea » Sat Apr 09, 2005 6:11 pm
it seems like it's not firing everytime on every cylinder
anythought on what could be causing it?
1goodidea
Postby Virtual Genocide » Sat Apr 09, 2005 6:47 pm
Hi
Get yourself a timing light to find out if its running on all cylinders. The 2k exhaust should be ok, top end I imagine will be quite poor however. I would suspect your idle problems will be electrical or fuel related.
Any more questions just ask :)
Phil
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby _will_ » Sat Apr 09, 2005 7:24 pm
Have you tried adjusting the idle speed and mixture? There are a couple of screws on the side of the carb which you can fiddle with to smooth out/speed up the idle.
The problem could also be a vacuum leak in one of the lines somewhere.
Celica GT-Four ST185
Starlet KP61
http://toyspeed.blakjak.net/profiles/profile.php?id=1304
I don't always not make no sense
_will_
Postby 1goodidea » Sat Apr 09, 2005 7:48 pm
_will_ wrote:Have you tried adjusting the idle speed and mixture? There are a couple of screws on the side of the carb which you can fiddle with to smooth out/speed up the idle.
yip tried playing round with this!
don't think its firing consistantly on every cylinder, how will a timing light determine whether it is or not?
1goodidea
Postby phat5k » Sat Apr 09, 2005 8:47 pm
2K exhaust works fine! there all th same! but stock is gutles! id say u have an eletrical fault. checked ur plugs? leads? distributor?
i like desprung :) it makes titties bounce!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1362
phat5k
Postby RS13 » Sat Apr 09, 2005 10:35 pm
I put a 4K into a 2K starlet, I found that the 2K exhaust was a single pipe from the manifold, whereas the 4K had twin pipes from the manifold, going into 1 pipe under the firewall. And oddly enough, I had a lot better performance using the 2K carb on the 4K.
RS13
Postby phat5k » Sun Apr 10, 2005 5:08 pm
wen my 4k was put in2 my 2k starlet it had extractors on it! so opvoisly im nt gona kno much bout th manifolds, but my 2k exhaust managed to rip of th extractors at th join! an it wasnt dodgy welding eather! so id say get rid of th 2k exhuast if u wanna go fast!
and RS13 did u eva thnk of cleaning ur 4k carb??
phat5k
Postby RS13 » Sun Apr 10, 2005 7:33 pm
The 2K carb had a larger secondary, over the 4K carb. Why? I have no idea.
RS13
Postby TygerTung » Mon Apr 11, 2005 1:15 pm
We put a 4K in my friends KP60 which originally had a 2K. Went fine
TygerTung
Postby ee904age » Mon Apr 11, 2005 1:39 pm
Timing lights work off the signal going through the lead, so if you hook the light up to one lead at a time it will tell you which (if any) has no power.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby 1goodidea » Mon Apr 11, 2005 7:59 pm
what i wanted to hear! i thought you could only do the timing off the 1st cylinder?
should the timing light flash consistantly if it's firing properly as when we tried to adjust the timing the light would flash consistantly and then stop then flash consistantly again like what i would assume a miss is
1goodidea
Postby Virtual Genocide » Mon Apr 11, 2005 8:50 pm
Correct, the light should constantly flash.
I'd start by lifting off the distrubutor cap and looking to see that all the parts are nice and clean and free from "burn marks" on the contacting points, then if you think you're up to it pull of the rotor and cover to check the points. Might also be a good idea to put a multi meter on each end of the HT leads to see how many ohms of resistance there is and pull the spark plugs out to make sure they look ok aswell.
Another possibility is the carburettor, you could could try spraying it with some carb cleaner or running a fuel cleaner in you tank. Check your air fliter they can get very clogged up with dirt/dust.
Phil
Virtual Genocide
Postby 1goodidea » Tue Apr 12, 2005 8:13 am
Virtual Genocide wrote:Correct, the light should constantly flash.
Phil
Thanks
Yip i've had plugs out cleaned and checked the gap, i replaced rotor, dizzy cap and leads with the leads off my 2k which worked mint and still no change
1goodidea
Postby RS13 » Tue Apr 12, 2005 9:51 am
Is it a 4K-U? If it is, it may be that you have a leak in one of the many, many vacuum lines around the motor. I did in my KE70, I removed most of the vacuum lines and bits and pieces, took a while to block the right hoses, but now she idles as smooth as a swedish supermodels' ass! I did it because it sounded like it was running on 3 at idle, but when revved, it seemed to run on 4.
RS13
Postby 1goodidea » Tue Apr 12, 2005 1:39 pm
RS13 wrote:Is it a 4K-U? If it is, it may be that you have a leak in one of the many, many vacuum lines around the motor. I did in my KE70, I removed most of the vacuum lines and bits and pieces, took a while to block the right hoses, but now she idles as smooth as a swedish supermodels' ass! I did it because it sounded like it was running on 3 at idle, but when revved, it seemed to run on 4.
Yip thats the symtoms exactly!
I'm not sure if it's a 4K-U? how do i tell, it was out of a 1986 Dx corolla wagon.
what is the valve/(connection where a vacum line could attach) that is on the intake manifold close to the 1st cylinder or front of the car? i blocked it and the car blew so much smoke it wasn't funny!
the thing is it was running badly before i put the 4k carb and manifold on
1goodidea
Postby RS13 » Tue Apr 12, 2005 9:06 pm
Vacuum lines EVERYWHERE! Also, the 4K-U has a little pipe that goes from the exhaust manifold, around the front of the motor, to a little valve that looks like a UFO, then into the airbox. Also, on the waterpump/thermostat, there are 2 little rods sticking out, with 2 vacuum hoses each on them, going to the carb. Me, I ripped it all off, blocked what had to be blocked.. idles awesome now. Chances are, you've got a leak somewhere, or one of the vacuum valves might be knackered.
RS13
