pervert wrote:It shouldn't do, I would imagine the exhaust diameter would be the same, but I could well be wrong...
_will_ wrote:Have you tried adjusting the idle speed and mixture? There are a couple of screws on the side of the carb which you can fiddle with to smooth out/speed up the idle.
The problem could also be a vacuum leak in one of the lines somewhere.
1goodidea wrote:
don't think its firing consistantly on every cylinder, how will a timing light determine whether it is or not?
Timing lights work off the signal going through the lead, so if you hook the light up to one lead at a time it will tell you which (if any) has no power.
Virtual Genocide wrote:Correct, the light should constantly flash.
I'd start by lifting off the distrubutor cap and looking to see that all the parts are nice and clean and free from "burn marks" on the contacting points, then if you think you're up to it pull of the rotor and cover to check the points. Might also be a good idea to put a multi meter on each end of the HT leads to see how many ohms of resistance there is and pull the spark plugs out to make sure they look ok aswell.
Another possibility is the carburettor, you could could try spraying it with some carb cleaner or running a fuel cleaner in you tank. Check your air fliter they can get very clogged up with dirt/dust.
Phil
RS13 wrote:Is it a 4K-U? If it is, it may be that you have a leak in one of the many, many vacuum lines around the motor. I did in my KE70, I removed most of the vacuum lines and bits and pieces, took a while to block the right hoses, but now she idles as smooth as a swedish supermodels' ass! I did it because it sounded like it was running on 3 at idle, but when revved, it seemed to run on 4.
Users browsing this forum: No registered users and 32 guests
